Author Topic: Ortholinear 45% keyboard ISO enter IDEA  (Read 4410 times)
Offline MC Qwerty
« on: Sun, 13 May 2018, 13:15:45 »
So I was just designing a keyboard and I came up with this layout,
I just wanted to see what people thought, I would probably make it open source:
Better one, made by Parva Ovis (thanks agian)
So its an ortholinear keyobard but with,
ISO enter
6U spacebar
1.5U side keys
I wanted to know if people would want this or know how to make a PCB like this,
Thanks,
« Last Edit: Sun, 13 May 2018, 14:30:25 by MC Qwerty »
MC Qwerty
Re: Ortholinear 45% keyboard ISO enter IDEA
« Reply #1 on: Sun, 13 May 2018, 13:24:05 »
The ISO enter key doesn't work with an ortho layout as it's wider at the top, not sure what you're going to use as a 2.5u backspace either.
You could use the enter key from a number pad if you wanted a tall one?  Though it would be a bit weird with cherry profile caps...
Offline MC Qwerty
« Reply #2 on: Sun, 13 May 2018, 13:28:28 »
I unfortunately could not convey the space between ISO enter, but I would probably use a spacer to allow the ISO enter to fit.
MC Qwerty
Offline Parva Ovis
« Reply #3 on: Sun, 13 May 2018, 13:35:35 »
Use Keyboard Layout Editor to see how the keycap sizes actually relate to one another proportionally. For example, what it would look like with your given key sizes and one I whipped up for comparison.
Offline MC Qwerty
« Reply #4 on: Sun, 13 May 2018, 14:27:01 »
Wow man this is awesome thanks, and these are both really close to my design, thanks so much man, is their any user guides and stuff :),
Thanks again Parva
MC Qwerty
