Author Topic: (Identified as rubberdome)Unisys/Burroughs K-2 Keyboard  (Read 7645 times)
Offline ag36
« on: Fri, 18 May 2018, 05:13:32 »
https://www.ebay.co.uk/itm/Vintage-Unisys-Burroughs-K-2-Keyboard-for-B25-Computer-System-B25-K5/282962733775
Look quiet decent, capacitive keyboard?
Edit:Might be just a rubber dome.
« Last Edit: Sat, 19 May 2018, 10:13:03 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Foil over dome with dye sub caps? Unisys/Burroughs K-2 Keyboard
« Reply #1 on: Fri, 18 May 2018, 05:32:33 »
Looks very much like a standard rubber dome to me Oo .
Offline ag36
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Fri, 18 May 2018, 09:56:02 »
Is this not this? https://deskthority.net/photos-f62/burroughs-b25-k2-3675-6104-t12617.html
Don't think so. That's Brother dome and foil, AKA Prototopre. That's a dome-with-slider design at heart though, and on the listing's picture you can see that the plunger is part of the keycap, NOT a separate slider. Might still be dome and foil, but I highly doubt it.
Offline ag36
Re: Unisys/Burroughs K-2 Keyboard
« Reply #4 on: Fri, 18 May 2018, 10:30:48 »
Huum, I see.
Offline mrhead
  • Thread \ (•◡•) / Stopper
« Reply #5 on: Fri, 18 May 2018, 16:45:58 »
Looks like the OP posted one that is a later revision.  Too bad, because I love that keyboard layout from HaaTa's thread on DT.
Offline orihalcon
« Reply #6 on: Fri, 18 May 2018, 22:24:20 »
There is a similar looking Burroughs keyboard that is ITW magnetic valve as well, though this isn't it :/
