Author Topic: [IC] OXALYS80 TKL - Limited Quantity  (Read 55182 times)
Offline Nixytheria
  • nix studio
    • Instagram
Re: [IC] OXALYS80 TKL - PROTOTYPE IS FINISHED
« Reply #50 on: Fri, 13 July 2018, 10:58:49 »
~ New pictures Added !
Offline mkarlsson
« Reply #51 on: Sat, 14 July 2018, 14:43:00 »
It looks nice, but it seems that the keycaps do not fall into place like it should, looks like there is a small gap between the caps and case...
Offline wholypantalones
  • text and icon mods plz.
« Reply #52 on: Sat, 14 July 2018, 14:54:34 »
Looks as though it's the top left corner, or just the angle. The caps to seem to sit higher than the case.
Offline Nixytheria
  • nix studio
    • Instagram
Re: [IC] OXALYS80 TKL - Detailed Pictures Added
« Reply #53 on: Sat, 14 July 2018, 16:16:00 »
For that problem is because of the plate had a problem. The switch can't clipped to the plate. Easy to be put off. I already fix the build and the keycaps is back to normal
Sent from my SM-N915F using Tapatalk
Offline mkarlsson
« Reply #54 on: Sun, 15 July 2018, 06:00:26 »
In such case I don’t see any other issue. I like it a lot, would like to see other colors though.
When do you plan to run the GB? I would like to join...
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #55 on: Sun, 15 July 2018, 10:41:33 »
[/quote]
Thankyou for your comment
I planning for run the GB at this sept or Oct, since i haven't found the hardshell case maker for the packaging i can't run the GB
Stay tuned :) for the other colors sample, i don't have. But i will using pantone number for the anodizing process. the result should close with it
Offline mkarlsson
« Reply #56 on: Sun, 15 July 2018, 11:32:22 »
Quote from: mkarlsson
Good timing for me, joined several GB’s recently.
Have a couple of questions:
1. What will be the default color options?
2. Will the pcb support ISO?
3. Any option you would share the plate CAD file so we may be able to do our own plates? I want a PC fixed ISO plate like I did for my 8X. Or maybe you could offer such thing?
4. Did you try any other font for the weight? Have thought something about that?
« Last Edit: Sun, 15 July 2018, 12:53:16 by mkarlsson »
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #57 on: Sun, 15 July 2018, 13:50:29 »
Regarding your question.
1. The Color option would be Dark Blue, Red, Silver, Black, Dark Purple, Cyan. FYI you can request the color just mention the color number. But it will takes more money
2. As you can see in the first page. it's support ISO layout
3. Polycarbonate plate option added
4. Check the first page. it has been edited
Thanks
Offline mkarlsson
« Reply #58 on: Sun, 15 July 2018, 14:17:29 »
Thanks
Thanks a lot for your reponses.
1. Nice options. I will consider either dark blue or black. And the fact that you offer custom colors is amazing.
2. Sorry I missed that one. My fault.
3. Nice! But I guess it will be a universal option (ANSI/ISO combined). Would you still consider sharing the CAD files so we can do an ISO or ANSI only plate?
4. Much more classy. I like it.
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #59 on: Sun, 15 July 2018, 14:21:20 »
Thanks
Shared CAD files would be added after Group Buys end, like other case. CAD for plate will be shared after the GB is finished
Offline mkarlsson
« Reply #60 on: Sun, 15 July 2018, 14:26:56 »
Thanks
Sure, did not mean to share it now. Just wanted to confirm if you would be willing to do so. So...perfect!
Thanks a lot.
Offline Giorgio
« Reply #61 on: Sun, 15 July 2018, 16:22:10 »
That's really nice.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #62 on: Mon, 16 July 2018, 04:42:38 »
Yup the simple font is way better on the weight.
Sent from my mobile using Tapatalk
Offline Nigolski
« Reply #63 on: Mon, 16 July 2018, 06:57:08 »
the case could be a little bit taller so the keycaps would have a sunken in look, but this still looks amazing  :thumb:
Offline mkarlsson
« Reply #64 on: Mon, 16 July 2018, 07:44:14 »
Check some posts above. It was a problem with plate, that’s fixed.
Offline redbanshee
  • actually Dade Murphy
« Reply #65 on: Mon, 16 July 2018, 10:37:35 »
Offline Gobluebro
« Reply #66 on: Mon, 16 July 2018, 11:03:07 »
I love the new font. I'm totally in for this when group buy comes
Offline Nixytheria
  • nix studio
    • Instagram
Re: [IC] OXALYS80 TKL - Limited Quantity
« Reply #67 on: Wed, 01 August 2018, 11:58:36 »
slot info updated
Offline Jkush463
« Reply #68 on: Thu, 02 August 2018, 18:53:43 »
no hate but this reminds me of a knock off kn2.10
Offline xondat
  • i'm not a star
« Reply #69 on: Thu, 02 August 2018, 18:55:47 »
This was started before KN2.10 was public FYI.
Offline W00gala
  • Professional Lurker
« Reply #70 on: Thu, 02 August 2018, 19:11:21 »
I approve of the new font.
Offline Jkush463
« Reply #71 on: Thu, 02 August 2018, 19:49:31 »
Ah, i see.
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #72 on: Fri, 03 August 2018, 02:12:12 »
Thanks for your explaination  :thumb:
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #73 on: Thu, 09 August 2018, 14:56:23 »
[size=18]GB DATE ANOUNCED[/size]
Sent from my ASUS_Z01MD using Tapatalk
Offline Gobluebro
« Reply #74 on: Mon, 01 October 2018, 10:06:25 »
For those still watching this thread. The Group buy has started here https://geekhack.org/index.php?topic=97531.0
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #75 on: Fri, 11 January 2019, 22:50:08 »
Thankyou pal
