Author Topic: [IC] OXALYS80 TKL - Limited Quantity  (Read 54632 times)
Offline Nixytheria
  • nix studio
    • Instagram
« on: Fri, 18 May 2018, 18:13:06 »
OXALYS80
TKL keyboard
Here's OXALYS80 , The TKL size keyboard that comes with Winkeyless Layout and Standard TKL Layout .
More image renders: https://imgur.com/a/H5ZiRKq
There would be a change in the brass weight font, as per people request i change it to simple font
Features
- 8° Angled
- 6061 Anodized Aluminum
- Stainless Steel or Brass Plate
- Brass Weight with polished finish
- Weights ±3.6kg / ±8lbs
- h87 OXALYS TKL by Hineybush
- Will be packed in Hardshell Case
Supported Layout
Color Variation
- Black (Hard Anodized)
- Silver (Hard Anodized)
- Red
- Dark Blue
- Champagne Gold
- Rose Gold
Quantity Limited for 25 units only
Pricing
Price $430 Including
-Case
-SS Plate
-Brass Weight
-PCB
Additional
-Brass Plate $50
-Polycarbonate Plate $40
-PCB $45
IC Form
https://docs.google.com/forms/d/e/1FAIpQLScqEXje2kxrNlYfmTj2QFPVYxtNDkCDVSmHqYNc8Iz31DrjWA/viewform
GROUP BUY WILL START AT OCTOBER
Wish to fulfill your inquiry please leave your comment bellow.  :thumb:
Update
25/06/2018 - Starting a prototype production
02/07/2018 - Finished a Prototype
13/07/2018 - Assembled and New Pictures Updated
« Last Edit: Fri, 10 August 2018, 23:24:09 by Nixytheria »
Offline p_blaze
Re: [IC] OXALYS87 - TKL | Custom TKL Keyboard
« Reply #1 on: Fri, 18 May 2018, 18:20:39 »
dang that looks good, looking forward to see the prototype
any chance for a daughterboard so that people can use other types of USB connectors?
what is the height of the front of the keyboard, and is there any chance for customization like using 7075 or 5052 aluminum or pantone color matching?
will the brass be electro/nickel plated to stop tarnishing?
« Last Edit: Fri, 18 May 2018, 18:35:21 by p_blaze »
Offline jlee755
« Reply #2 on: Fri, 18 May 2018, 18:27:04 »
So many TKLs, what's going on? Did everyone just decide this month is for TKLs?
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #3 on: Fri, 18 May 2018, 18:33:17 »
I dunno, but i really love this layout so I create this one
I think you can use Nerd TKL ver.2 pcb with usb on the bottom that available at 1upkeyboards  ;D
Offline crusader_alex
« Reply #4 on: Fri, 18 May 2018, 18:44:54 »
This looks really good,will there be any other color options?
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #5 on: Fri, 18 May 2018, 18:51:16 »
For 7075 there would be additional price because that material is quite expensive.
The front height is about 2cm
I will coat the brass with nickle to avoid tarnishing (maybe)
Sent from my SM-N915F using Tapatalk
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #6 on: Fri, 18 May 2018, 18:52:08 »
For the color options will be updated as soon as possible
Offline p_blaze
« Reply #7 on: Fri, 18 May 2018, 19:01:31 »
Those would be really attractive options, especially if the factory you are producing this at can anodize 7075 well.
My fingers are crossed for nickel plating, it is without a doubt my favorite finish for brass.
Hopefully this runs a bit later in the year so I can get my wallet ready :P
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #8 on: Fri, 18 May 2018, 19:05:40 »
Wish for your information, i'll make the prototype at the end of this month (end of may) . The groupbuy TBA
Offline Dumblescore
« Reply #9 on: Sat, 19 May 2018, 00:04:08 »
I’m not the biggest TKL fan but this might be the exception.  Is it only going to be winkeyless?  Any plans for other layouts if this one is successful?
Offline _rubik
« Reply #10 on: Sat, 19 May 2018, 00:38:04 »
I'll be interested to see the prototype. I feel like there has been a recent saturation of the market with alu tkl cases at the 400 dollar mark.
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #11 on: Sat, 19 May 2018, 00:39:44 »
If you interest to buy this, Surely i can provide the standard layout for you  :D
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #12 on: Sat, 19 May 2018, 00:56:00 »
IC Form has been created, wish you guys to submit the IC Form  ;D
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #13 on: Sat, 19 May 2018, 00:58:27 »
Hopefully the prototype can be done at the end of May or Middle April . Just stay tuned and don't forget to fill the IC form :)
« Last Edit: Sat, 19 May 2018, 01:00:26 by Nixytheria »
Offline Mousy
  • I <3 tootall
    • IG
« Reply #14 on: Sat, 19 May 2018, 02:59:13 »
Is it right where it says it is +-30KG? That seems extremely heavy
- White Kira 60 | Black Kira 60 | TGR Jane v2? -
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #15 on: Sat, 19 May 2018, 03:04:05 »
It's 3.0 kg. It's a typographical error.
Sent from my mobile using Tapatalk
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #16 on: Sat, 19 May 2018, 03:19:36 »
Thankyour for your reminder, just edited.
And also thankyou for helping for the answer
If you don't mind, wish you to fill the IC form, thankyou :D
Offline HardcoreDesk
« Reply #17 on: Sat, 19 May 2018, 10:25:50 »
Why name it 87 instead of 8 4 if it's going to be WKL? Just curious, the board looks great.
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #18 on: Sat, 19 May 2018, 10:54:16 »
Thankyou. Because the standard TKL size is 87. Just to make people know that this keyboard is TKL layout.
Don't forget to fill the IC form. Thankyou
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #19 on: Sun, 20 May 2018, 12:33:38 »
UPDATE | We have contacted the CNC service, and waiting for the quotation for the price and will make the prototype later on!  ;D
Offline Jimmare
« Reply #20 on: Mon, 21 May 2018, 04:40:15 »
Im actually really interested, i think it looks awesome. Also the dark/navy blue on the render looks amazing!
I would (and i thought we all do) like some renders on the back and sides. Have you thought adding anything on the front -above arrows- like most of the kustoms do or do you wanna keep it clean from stuff like these?
Last thing,the pricing. Im really into the keyboard but it has the same pricing as a MIRA and 2/3 of the weight. Im not sure if i wanna buy in,considering the value of it,especially if the gb starts before july...
This is the only i've seen....Which are the others anyway?
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #21 on: Mon, 21 May 2018, 06:29:38 »
Actually this is just an estimated weight by calculate it in fusion360. For the actual weight we can't make sure unless the prototype is done.
Thankyou for your comment, please don't forget to fill the IC form.
Regards
Nixy
Offline jlee755
« Reply #22 on: Mon, 21 May 2018, 10:15:27 »
There's Kira TKL and Noxary 280 off the top of my head.
Offline mkarlsson
« Reply #23 on: Mon, 21 May 2018, 14:13:45 »
Very very nice keyboard. If I have the money when the time comes I will join. I would miss a polycarbonate plate option though...
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #24 on: Mon, 21 May 2018, 16:10:40 »
Thanks.... just save your money until the GB start for the polycarbonate plate i'll check it for the availability first
Offline mkarlsson
« Reply #25 on: Mon, 21 May 2018, 17:26:11 »
thanks!
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #26 on: Tue, 22 May 2018, 11:46:08 »
- Drawing Picture Added -
Offline Createboardhk
    • Createboard
Re: [IC] OXALYS87 - (Looking for Manufacturer)
« Reply #27 on: Wed, 23 May 2018, 13:21:40 »
Yes! please make it realize!
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #28 on: Wed, 23 May 2018, 13:24:35 »
Still looking for prototype maker (manufacturer) .
Thankyou for your comment. Please fill the IC form :)
Offline afrokobe
« Reply #29 on: Thu, 24 May 2018, 14:57:43 »
Is your proto being manufactured at a different place?  How do you have price quotes?
Offline Nixytheria
  • nix studio
    • Instagram
Re: [IC] OXALYS87 - (Looking for Maker)
« Reply #30 on: Thu, 24 May 2018, 16:15:26 »
I already get some maker and have a quote from them. But the price is out of my range. And still looking for other manufacturer
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #31 on: Fri, 25 May 2018, 05:51:51 »
Looks good! I'm interested!
    • Createboard
« Reply #32 on: Fri, 25 May 2018, 07:00:30 »
Forget to ask, What color do the case can choose?
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #33 on: Fri, 25 May 2018, 07:30:28 »
Thankyou, don't forget to fill the IC form for our refference
For the color will be decide after the IC is finished. Obviously i choose depends on the IC Form. Please make sure that you are fill the IC form. Thank you   :D
    • Createboard
Re: [IC] OXALYS80 TKL - (Looking for Maker)
« Reply #34 on: Fri, 25 May 2018, 11:28:35 »
Already filled! looking forward to it! :D :D :D
Offline Nigolski
« Reply #35 on: Fri, 25 May 2018, 16:32:15 »
my wallet is ready
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #36 on: Sat, 26 May 2018, 00:27:18 »
my wallet is ready
Thankyou guys, just wait until the GB start :D
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #37 on: Sat, 26 May 2018, 01:01:47 »
New Picture Added for standard layout TKL  :thumb:
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #38 on: Wed, 06 June 2018, 10:24:30 »
[UPDATE]
-new renders color
- [Status] waiting for quotation from the maker.
- estimated the prototype will be made this month
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #39 on: Mon, 25 June 2018, 10:08:25 »
UPDATE! Prototype in production
Offline mkarlsson
« Reply #40 on: Mon, 25 June 2018, 10:21:28 »
Nice!
Offline Nixytheria
  • nix studio
    • Instagram
Re: [IC] OXALYS80 TKL - PROTOTYPE IS FINISHED
« Reply #41 on: Tue, 03 July 2018, 10:58:55 »
FINALLY! PROTOTYPE PHOTOS UPDATED  ;D
Offline mkarlsson
« Reply #42 on: Tue, 03 July 2018, 11:20:12 »
Very nice, the only thing I would change is the font used in the weight.
Offline Gobluebro
« Reply #43 on: Tue, 03 July 2018, 11:54:11 »
Agreed I'm not feeling that font. Otherwise this stuff looks amazing I love it
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #44 on: Tue, 03 July 2018, 11:55:17 »
Do you guys have an idea for the font?
Offline Gobluebro
« Reply #45 on: Tue, 03 July 2018, 12:19:44 »
I'm a fan of Sans in most cases but I'm sure I don't speak for everyone. I just ran the name OXALYS'80 through some fonts on DaFont's website.
Here are the ones I was enjoying the look to.
https://imgur.com/a/uVZu6cl
Also I know nothing about fonts on weights so sorry if this is not helpful.
Offline mkarlsson
« Reply #46 on: Tue, 03 July 2018, 14:26:40 »
I don’t know if there’s a theme behind this board, but to me looks quite modern, I would go for something like that, clean, simple but modern.
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #47 on: Tue, 03 July 2018, 17:55:46 »
Thankyou guys. Will be update the brass design soon.
Offline Altain
  • Formerly zungzangbi
« Reply #48 on: Thu, 05 July 2018, 00:29:38 »
Really looking forward to seeing the actual production go live! Great works  :D
with decent price I am also willing to join GB. Keep up the update please  :thumb:
Offline Nixytheria
  • nix studio
    • Instagram
« Reply #49 on: Thu, 05 July 2018, 05:38:41 »
Will be updated as soon as the case arrived to me  :thumb:
