Author Topic: Dell AT101 GYUM97SK Keycaps ABS or PBT?  (Read 6140 times)
Offline Sick Robotron
« on: Fri, 18 May 2018, 20:54:20 »
https://imgur.com/gallery/YtgYnez
Hey guys -I recently picked up this keyboard on eBay. When it arrived, the switches were so full of grime and dust that it was practically unusable (it almost felt as if the sliders were coated in sandpaper!!) I commenced with the requisite soaking of the keycaps in warm soapy water for a few hours while I opened up each switch to remove whatever was causing them to feel like absolute ****. An entire can of air and ~40 cutips later, and now the keyboard feels and sounds fantastic.
There is one thing that has left me perplexed however...
I have heard only that this keyboard uses thin, dye-sublimated, ABS keycaps, yet, somehow these keycaps have no yellowing (nor any ABS style shine) on them at all while the case has ...not terrible, but considerable yellowing. Is there any way to know for sure if they are PBT or ABS?
Re: Dell AT101 GYUM97SK Keycaps ABS or PBT?
« Reply #1 on: Sat, 19 May 2018, 08:24:20 »
ABS can't be dye-subbed as I understand it.
If you have acetone, dab a tiny drop of it on the underside of a cap. It will melt ABS and create a little streak or dimple, PBT is impervious to acetone.
- D Trump 2026-10-24
Offline p_blaze
« Reply #2 on: Sat, 19 May 2018, 12:27:43 »
If I remember correctly, that is the oldest at101 model and should definitely be dye-subbed caps
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Sat, 19 May 2018, 12:57:23 »
Quote from: Sick Robotron
It's the oldest model made by _Silitek_, but before that there were Alps-made models. This one already has SKCM Black switches. Not sure, if it has PBT caps, it could be printed (silkscreen?) ABS.
« Reply #4 on: Sun, 20 May 2018, 13:04:15 »
Yes but this board has SKCM Black Pine switches which feel far superior to the black bamboo switches found in all new logo Dell AT101s.
« Reply #5 on: Sun, 20 May 2018, 13:08:33 »
I will give that a try. Thanks!!
Offline davkol
« Reply #6 on: Sun, 20 May 2018, 14:11:32 »
FYI some new-logo AT101s still have SKCM Salmon and some AT101Ws are rubber domes.
Regardless, your keyboard was made during the transition period, i.e., the keycaps can go either way.
« Reply #7 on: Sun, 20 May 2018, 14:19:39 »
I'm pretty sure that the rubber dome version is 101R/102R.
« Reply #8 on: Sun, 20 May 2018, 16:34:40 »
Didn't realize any new logos had salmons.
Also  - is it accurate that black pines were used only in the BUll 1971 and AT101 (as cited on deskauthority -- actually desk authority doesn't even say that AT101s have pines)?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #9 on: Sun, 20 May 2018, 17:06:06 »
Really? I've never seen that before. Do you have an example of this?
Offline davkol
« Reply #10 on: Mon, 21 May 2018, 02:45:15 »
AT102
« Reply #11 on: Mon, 21 May 2018, 08:23:40 »
Too cool!! Thanks for sharing :)
Offline chyros
  • a.k.a. Thomas
« Reply #12 on: Mon, 21 May 2018, 10:40:54 »
AT102
Pretty cool! Was it made by Alps or Silitek?
Offline davkol
« Reply #13 on: Mon, 21 May 2018, 12:26:19 »
It's still GYIAT101-102, made in Ireland.
Offline chyros
  • a.k.a. Thomas
« Reply #14 on: Mon, 21 May 2018, 17:04:39 »
Ah, so still an Alps board, just with a new logo. Interesting, I had never seen that before. Do you own that board? Maybe it's a shell refurb, or a Silitek-delivered one. AT101s usually came with time wheels, so if that's the case the shell would have a mismatching date with the other components in the keyboard.
Offline davkol
« Reply #15 on: Tue, 22 May 2018, 13:28:48 »
The chassis is from spring '94: top part February, bottom part April. PCB from May '93 (made in Korea).
edit: typo
« Last Edit: Tue, 22 May 2018, 13:43:01 by davkol »
Offline chyros
  • a.k.a. Thomas
« Reply #16 on: Wed, 23 May 2018, 00:56:53 »
edit: typo
Seems original then. Noice, quite a find!
