Author Topic: Taking keycaps on and off: does it contribute to key wobble?  (Read 6361 times)
Offline AugustCanaille
I got one of those Kailh BOX Switch testers, with the nine main types. Without the caps I used my fingers and they felt smooth, much smoother than Cherry or any other MX clone. In playing around with these, I took my sample pack of R1 keycaps from WASD and tried to match every color of BOX switch to every keycap. As I did this over and over (probably 5-7 times for each keycap) I noticed that there was more key wobble. I looked underneath: the female cross-stem had visible signs of wear and tear, and even had faded a bit, from when plastic is strained. Now, the original keycaps that came with the tester were R3 clears, and VERY hard to pull off.
So I'm wondering: when I get my final board, or at least a set of switches and caps I know will be my endgame, should I put them one once and NEVER take them off, at least until maintenance or replacement? I really do think that the keys wobble a lot more, and this may not matter to a lot of enthusiasts, but this is pretty much the main thing I care about. I want my fingers to feel like they are resting on stone columns, not Jenga blocks.
(Any tips to mitigate wobble would be much appreciated.)
Offline Tactile
Re: Taking keycaps on and off: does it contribute to key wobble?
« Reply #1 on: Sun, 20 May 2018, 21:30:07 »
There's a trick that's used on loose stabilizer inserts but I don't see any reason you couldn't do the same on any keycap you feel is loose.
REΛLFORCE
« Reply #2 on: Mon, 21 May 2018, 00:54:34 »
Interesting. I was thinking of trying this, but specifically with cling wrap or shrink wrap.
Offline Coreda
« Reply #3 on: Mon, 21 May 2018, 01:38:44 »
Is this a common problem with these switches? I couldn't imagine not removing keycaps periodically for cleaning reasons.
« Reply #4 on: Mon, 21 May 2018, 12:49:18 »
True, especially with BOX switches. But some people like to color-code them, move them for DVORAK prgramming, perhaps just fool around with designs. Now that I know this, I'm not going to. Maybe WASD keycaps are ****, but the cross-stems underneath are definitely showing signs of stress wear. So, yeah, cleaning is superfluous for Kailh BOX...at least periodically. Maybe once every few years?
Offline DirtyMonkey43
« Reply #5 on: Wed, 06 June 2018, 22:43:59 »
I havnt thought about this much. Just built a board with BOX and will be testing it out some
Offline Astrasa
« Reply #6 on: Thu, 07 June 2018, 02:26:03 »
Not that I have box switches to answer your question (sorry) but is key wobble in general a bad thing or could wobble lead to switch damage? I change my keycaps fairly often just to shake up the look of my board but maybe I shouldn't be doing that...
Kyuu Proto | Quasi Alice | Duck Viper | Tx87-Se
Offline nimblejacks
« Reply #7 on: Sat, 09 June 2018, 08:48:48 »
Would love a definitive answer on this topic since I am such a sucker for switching up my keycaps  :-[
