Author Topic: Abs m1 $20 shipped  (Read 18074 times)
Offline erricrice
Abs m1 $20 shipped
« Reply #50 on: Wed, 21 April 2010, 22:27:35 »
Ooops, nope, looked again and they are the Fukkas, I forgot what they looked like it's been so long since the 'fiasco'!!  lol
Still the big text though, which is weird since they have updated pics on newegg with the small text for nearly a year now...
« Last Edit: Wed, 21 April 2010, 22:31:18 by erricrice »
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline Otterclock
Abs m1 $20 shipped
« Reply #51 on: Wed, 21 April 2010, 22:46:33 »
Quote from: ripster;174291
This mod post shows ALPS assembly/reassembly.  Given that these M1s are simplified switches I found the assembly procedure tricky.  There are double notches that the switch has to fit into.
Bummer if some of these are Type 2 (XMs) not Type 1 (Fukkas).
Many thanks, Ripster.:smile: I'm assuming the slider just comes out after pooping the top off. Well it's a $20 board so I guess the risk isn't too high. I'm gonna keep the pooping typo as is.
ABS M1|IBM Model M|Lite-On 1788|Cherry G83 6744LUAUS| Logitech S510| Scorpius M10| Cherry 11900.
Offline bitflipper
Abs m1 $20 shipped
« Reply #52 on: Wed, 21 April 2010, 23:39:44 »
I knew I bought that AEKII for a reason. I think I'll try this.
Offline wellington1869
Abs m1 $20 shipped
« Reply #53 on: Thu, 22 April 2010, 00:02:53 »
Quote from: Otterclock;174288
How does one go about this? Is there a thread or somethin that shows a step by step. Can it be done by not so bright people? Things I take apart tend to not work again.
Re: aekii rubber-dampened sliders into the fukka switch, these alps mod links might help:
Once you have the donor board, the following are useful, tho not necessary, to have:
-a keypuller from hooleon (see links below for details/info), $6
-a "splinter forceps" is the fastest way to open up the alps casing, see links below for deets. Ebay, few bucks.
-a tube of silicon grease (helps with reassembly of the alps switch), ebay, few bucks.
-a few small containers to store the alps switch components during assembly/dissembly; I use a $1 muffin baking pan from the supermarket for its 6 "container" compartments.
-a magnetic picker-upper thing (telescoping magnet on a stalk) is helpful to pick up springs and leafs quickly after you remove the upper housing, and also can help with reassembly of the alps housing later on. See below links for deets. Is a few bucks on ebay.
-a copy of aquakeytest.exe or its equivalent is helpful, to rapidly test the keys and isolate any problematic ones.
If you have the above, the entire slider-swap takes literally 20 minutes, you can do it while watching your favorite sitcom. Otherwise can take a bit longer. Its mechanically simple to do though, either way.
-see the faq link below for most common donor boards for dampened sliders. Go down to the FAQ and MOD sections at the bottom of the wiki:
 http://geekhack.org/showwiki.php?title=ALPS+switches#FAQs
-sound samples, before and after the mod:
http://geekhack.org/showwiki.php?title=Island:7217
-additional related threads from mods section:
http://geekhack.org/showwiki.php?title=Island:7018 ("removing an alps keycap without killing yourself")
http://geekhack.org/showwiki.php?title=Island:5452 ("tools for extracting alps switches")
http://geekhack.org/showwiki.php?title=Island:4901 ("Instructions: removing alps switch") (alternate, slower way)
http://geekhack.org/showwiki.php?title=Island:7121 ("Open/Re-assemble an Alps switch")
http://geekhack.org/showwiki.php?title=Island:7157 ("make your fukkas even smoother") if you want
http://geekhack.org/showwiki.php?title=Island:4999 ("Fun with AEKII") Some deets and info
The most important caveat is during reassembly: Dont force the top casing on, if you feel resistance, backoff and retry. The most common "issue" one sees after this mod is a key that doesnt seem to work after reassembly (on a given board, expect at least 2 keys to be that way). This is easily fixed tho, for those keys, you just separate the contacts on the alps switch slightly with a small flat screwdriver. Works every time. I have a pic of this somewhere on GH, i'll see if i can find it and link it here.
Ah, found it. Not a photo but a post in a helpful thread on "stuck fukka switch".  I can provide more details if anyone gets stuck, but dont panic if you find one or two switches not working afterwards, the fix is fairly reliable and simple unless you've totally crushed the contacts by forcing the upper housing back onto the switch. So yea, go gently during reassembly and everything will be okay.
« Last Edit: Fri, 23 April 2010, 23:41:40 by wellington1869 »
using: ms 7000/Das 3
Abs m1 $20 shipped
« Reply #54 on: Thu, 22 April 2010, 00:39:31 »
oops
Offline erricrice
Abs m1 $20 shipped
« Reply #55 on: Thu, 22 April 2010, 19:34:56 »
Lol!  My mod got linked!
Also, it looks like everyone is getting the old big-text 'boards.  I wondering if ABS is even actually shipping the small lettered ones, and if not, how did newegg get one to take pictures of.....?
EDIT:
We're spreading......
Now i want a Tactile Clicky KB, this is a damn addiction.
Lol:
FYI, the ABS does not have a steel plate.
« Last Edit: Thu, 22 April 2010, 19:44:25 by erricrice »
Logitech G5[/FONT]
Offline nowsharing
  • Swoop
Abs m1 $20 shipped
« Reply #56 on: Thu, 22 April 2010, 19:59:16 »
Oh god, not the giant lettering...I feel like I've been ripped off.
Offline TexasFlood
Abs m1 $20 shipped
« Reply #57 on: Thu, 22 April 2010, 22:57:52 »
Quote from: kohan69;173850
First thing I do when I get a keyboard is use PCCHECK (part of hirens bootcd) to test every key.
Good idea, just burned the latest version to help recover a relatives PC.  Didn't think of using it to check keyboard keys but it works great for that.
Offline itlnstln
Abs m1 $20 shipped
« Reply #58 on: Fri, 23 April 2010, 07:11:19 »
The small-lettered, Filco-like 'boards were the earlier version (I had 2 of these).  The later revisions (shipping now) have the larger font.
Offline erricrice
Abs m1 $20 shipped
« Reply #59 on: Fri, 23 April 2010, 08:47:33 »
Quote from: itlnstln;174813
Oh that's funny I thought it was the other way around lol.  I guess I got the new revision for my first 'board.  I thought that they changed it to the small font after that, but it must be the other way around haha.
Logitech G5[/FONT]
Offline Phaedrus2129
Abs m1 $20 shipped
« Reply #60 on: Sat, 24 April 2010, 21:04:16 »
Jesus fornicate.
Overclock.net M1 owners
Tator Tot
Skylit
AsAnAtheist
Waylo88
Clownfart
Riou
MeatloafOverdose
RMP459
Fshizl
Jyr
DefoLinY
chatch15117
88EVGAFTW
Ez12a
Craiga35
Pbpenguins412
Redmist
Matt*S.
Paio
GanjaSMK
TheWolfe
Fireman
Otterclock
MatthewK
garricktlee
r34p3rex
smartasien
jemping
sexybastard
xToaDx
Bandrew
not2bad
Forum
Jplaz
paquitox
nijikon5
Andy.Yung
The Master Chief
michaeljr1186
DaMirrorLink
wire
hubwub
PhRe4k
DUNC4N
liveify
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Abs m1 $20 shipped
« Reply #61 on: Sat, 24 April 2010, 21:41:01 »
Tator Tot. I think you should send him a PM about how you want to show her how to really touch type...
« Last Edit: Sat, 24 April 2010, 22:03:49 by Phaedrus2129 »
Offline InSanCen
Abs m1 $20 shipped
« Reply #62 on: Sun, 25 April 2010, 01:56:13 »
That's a lot of potential GH members.
Please tell me the majority aint kids with attitude problems...
Quote from: Phaedrus2129;175669
Jesus fornicate.
big list...
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline aegrotatio
Abs m1 $20 shipped
« Reply #63 on: Thu, 29 April 2010, 10:54:14 »
I am pretty happy with the two I got for $20 each and free shipping.  My thoughts are in the other thread: http://geekhack.org/showpost.php?p=177274&postcount=81
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
