Author Topic: Making new keycaps  (Read 4890 times)
Offline overflow
Making new keycaps
« on: Fri, 25 May 2018, 07:29:56 »
One of my favorite hobbies is making new keycaps (not completly new one because i used a unusable spare keycaps to make one). sadly I'm so noob to make one that it makes me to put quiet amount of time and effort to get a new keycap.  well but I'm just doing for my satisfaction, so there is no regret about it.
some may think it's a junk but i call them my treasure (because i made it and took my effort!)  ;D
these pictures shows process to make new keycaps!
(I used old keycaps and epoxy putty for material.)
196322-0
196324-1
196326-2
196328-3
196330-4
196332-5
196334-6
196336-7
196338-8
196340-9
« Last Edit: Fri, 25 May 2018, 07:31:27 by overflow »
Offline crystalhand
Re: Making new keycaps
« Reply #1 on: Fri, 25 May 2018, 09:08:41 »
That looks really good.  I have wanted to try my hand at making a keycap.  How difficult was the process and any tips for someone thinking of doing something similar?
Offline overflow
« Reply #2 on: Fri, 25 May 2018, 10:29:55 »
well as far as I know, it's one of the cheapest way to make an artisan keycap. That amount Epoxy putty is not a big deal in budget and you only need a keycap which has a decent stem on it.  ;)
I painted them with acrylic paint with a small cheap brush (and put some clear-colored top coat on it for durability).  again I'd certainly say that it is the best way to make a artisan keycap in terms of money efficiency. BUT the problem is the time and effort. unless you have enough time and patient (and some motivation craving for a unique keycap), it's probably one of worst ways to get a new keycap.
I personally think one of the great advantage of making keycaps with putty is that you need only 3 things ;  hand, any keycaps, small amount epoxy putty .
In terms of tips, there is not much thing to say. the experience making keycap may be your great teacher.
I started with slime monster keycap which is very simple one to make. and painting it helps you a lot to improve your skill!  :thumb:
If you have enough money, I'd recommend you to buy an airbrush. it is helps you a lot for time and effort.
why do i not use airbrush? I'm living at an apartment, and my neighbor and family will complain me about the noise and smell if i use it.
If you have any questions , ask me anything you have about making keycap with putty.
« Last Edit: Fri, 25 May 2018, 10:34:36 by overflow »
Offline goodman247
  • It's confirmed, I'm an idiot.
« Reply #3 on: Mon, 28 May 2018, 02:02:46 »
That does look decently well, I actually think a lot of the imperfection on the cap gives it some unique charater
Offline overflow
« Reply #4 on: Mon, 28 May 2018, 02:30:44 »
yes i personally agree with you. its kind of previllage that handmade keycaps only have. CNC or 3d printing cannot show some natural unique feeling. they are very accurate and the fact that other people also have same exact keycaps makes some people dissapointed  ( actually its my case).
Offline DirtyMonkey43
« Reply #5 on: Wed, 06 June 2018, 22:35:18 »
Those actually look really cool! And if you enjoy it, do it! :D
Offline overflow
« Reply #6 on: Wed, 06 June 2018, 23:37:00 »
Thx for cheering me up ! Im making 6.25 new spacebar and i ll show it here soon again thx
Offline lasernasaur
« Reply #7 on: Thu, 07 June 2018, 01:29:31 »
Damn they look pretty good! keep up the good job!  :thumb:
Offline HOBI3CAT
  • FraktalKaps.com
    • Fraktal Kaps Website
« Reply #8 on: Thu, 07 June 2018, 11:29:10 »
These are looking great! I say they are definitely NOT junk- keep up the good work!
Eat, Sleep, Resin, Repeat.
Offline dankdesire
« Reply #9 on: Thu, 07 June 2018, 12:12:19 »
Keep it up, really like the kind of rugged look
Offline anatworkaccount
« Reply #10 on: Thu, 07 June 2018, 12:29:53 »
Keep on going man, you have a good outlook.
