Author Topic: [IC] MDA(MIX) Big Bone Custom Keycap Set  (Read 41538 times)
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
Re: [IC] MDA(MIX) Big Bone Custom Keycap Set
« Reply #50 on: Thu, 07 June 2018, 21:41:38 »
Do you have specifics on what the actual kits will be? The way it's broken up in the picture is ~16 kits as laid out, which is pretty intense. I'm assuming spacebars/convex will be grouped into a single kit, and past Mix sets have included numpad in the base. Also, I'm not sure I understand what the R0 F-region kit is about. Mac kit could also be bundled into the Modifiers Extension or Exotic kit, IMO.
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline 0.01
« Reply #51 on: Fri, 08 June 2018, 00:16:22 »
All of kits will be available. The reason why we divided into so many kits because we don't want to people buy unwanted kits.
For the F-region kit that R0 profile is little higher than R1. so if you have 84 keyboard that would be very useful.
Offline 0.01
« Reply #52 on: Fri, 08 June 2018, 00:19:10 »
Been interested in this profile, hope the legends come out nice. Is there an estimated price?
yes, we have the price but it's not final price.  I can say that the price will be very reasonable.
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #53 on: Fri, 08 June 2018, 11:35:03 »
Would it be incorrect to think of this as sculpted XDA?
I have XDA on my daily driver but I'm really not digging the lack of sculpt so it's probably coming off soon.
Offline Zuology
« Reply #54 on: Fri, 08 June 2018, 12:19:30 »
Anecdotally, I don't think it's too far off. The dish is "flatter" towards the edges, so not as much of a lip/rim like XDA has, if that makes sense. The edges of each key flow more evenly into the surrounding keys, with less gap between each keycap's surface.
*Disclaimer, don't own XDA myself, but opinion based on a lot of heavy consideration of which XDA set I may eventually get (though I am not a fan of uniform/flat un-sculpted profiles based on my experience with SP's PBT DSA HC Granite)*
Offline Klackygears
« Reply #55 on: Fri, 22 June 2018, 21:03:40 »
From the Massdrop IC thread, there were requests for Colevrak and Ergodox sets - any chance of those??
I will discuss with our team about this thing. Thank you for your advice!
I really hope so! I'm in if there's Colevrak! Or blank for the alphas.
Offline Starston3
« Reply #56 on: Sat, 30 June 2018, 12:22:10 »
I'm in.
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #57 on: Wed, 11 July 2018, 20:54:52 »
https://kono.store/products/big-bone-keycaps
it seems pre-order has begun!  :thumb:
Note: this is a group buy. It will be open until August 20. The sets are expected to ship in late September.
ends 8/20, ship at the end of September <= so fast?  :eek:
is this set already in production?
Offline chuckdee
« Reply #58 on: Wed, 11 July 2018, 22:21:36 »
I don't see the extension kit on the store.
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #59 on: Wed, 11 July 2018, 22:33:33 »
If you mean the modifier extension kit, it is listed as the modifiers most likely as the base kit has ANSI mods already.
Offline sevenseacat
« Reply #60 on: Wed, 11 July 2018, 22:42:12 »
Seems Colevrak didn't make the cut... oh well.
Offline chuckdee
« Reply #61 on: Wed, 11 July 2018, 23:36:30 »
Yeah... I figured that out later.  At least I hope that's what it means.  More confusing than it needs to be...
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #62 on: Sun, 15 July 2018, 01:26:56 »
Is this only available on Kono?
Offline Zuology
« Reply #63 on: Fri, 12 October 2018, 14:47:25 »
Aware that there isn't a true "GB" post for this setup since it's being run through Kono and others, but any new with updates or samples/pics? Very much looking forward to R0 and Convex bottom row :D
Offline Madrobby
« Reply #64 on: Fri, 07 December 2018, 19:19:10 »
Hey there. I missed the GB deadline… :(
I'm looking for the Big Bone Exotic & Modifiers Extension kits. If anyone is up for selling those, please lmk!
Thanks,
Thomas
Offline nguyenhimself
« Reply #65 on: Fri, 07 December 2018, 21:34:28 »
Thanks,
Thomas
You can buy them on the KBDfans store right now.
« Last Edit: Fri, 07 December 2018, 21:36:02 by nguyenhimself »
Offline Madrobby
« Reply #66 on: Sat, 08 December 2018, 22:09:10 »
Thanks,
Thomas
They don’t include Exotic and not all modifiers (I did buy this set from them, but there’s no 1.5U ESC and Delete keys for my Vortex Race 3).
Offline Starius
« Reply #67 on: Tue, 29 January 2019, 19:20:47 »
I got my shipment notification from Kono!  Huzzah! :D
Offline Zuology
« Reply #68 on: Thu, 31 January 2019, 10:32:38 »
Got my set yesterday. Haven't done a full inspection but caught a 1.25 or 1.5u "CONTRL" key (spelled like that) while just checking through the sealed bag. Hopefully no other issues, but dye sub looks good, centered, not laser crisp but nicely consistent. Looking forward to setting up a full convex bottom row!
Offline oh_chesteroni
« Reply #69 on: Thu, 31 January 2019, 13:17:09 »
Based on the renders, the 1.5u contrl is correct and should be spelled that way
Offline Zuology
« Reply #70 on: Thu, 31 January 2019, 14:44:59 »
Guess that missed the spellcheck stage then :(
« Reply #71 on: Thu, 31 January 2019, 15:45:56 »
Looks to be the case, unless it was intentional, which is a poor choice imo.
Offline melgeek
  • MelGeek-Keyboards and Peripherals Manufacture
    • MelGeek
« Reply #72 on: Thu, 08 August 2019, 03:38:15 »
I'd be interested if there was an ortholinear option. :(
here is the link : www.melgeek.com
MelGeek- aim to bring the joy of using a mechanical keyboard to everyone.
Offline melgeek
    • MelGeek
« Reply #73 on: Mon, 23 September 2019, 22:22:48 »
Offline melgeek
    • MelGeek
« Reply #74 on: Mon, 23 September 2019, 22:27:40 »
Thanks,
Thomas
you can check https://discord.gg/uheAEg3 for details
Offline melgeek
    • MelGeek
« Reply #75 on: Mon, 23 September 2019, 22:36:53 »
