Author Topic: Help!!! Krytox lube on keycaps!!!  (Read 6547 times)
Offline Sick Robotron
« on: Fri, 01 June 2018, 06:32:49 »
Hey guys - anyone have advice on how to remove krytox lube on keycaps?
First of all - I am a complete ****ing idiot. I not only got a tiny bit of krytox on some keys on one board causing disastrous results, but worse, I tried to clean them by soaking in a tupperware with soapy water and it didn't work. Then yesterday I cleaned off some AEK keycaps and gave them a wash in the same basin and now they are luby too (madness inducing)!!! My life is becoming consumed by krytox almost to the point that I think I won't ever use the stuff again (the amount I got on the original caps was incredibly negligible but has basically made it so I can't type on the board without washing my hands 5x afterwards).
Any advice is much appreciated!! SOS!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Help!!! Krytox lube on keycaps!!!
« Reply #1 on: Fri, 01 June 2018, 06:44:18 »
Have you tried light petroleum ether or a comparable nonpolar solvent?
« Reply #2 on: Fri, 01 June 2018, 07:04:48 »
Chyros - Thanks so much for your response! I haven't tried ether. Can you recommend a brand and do you have any tips on application?
Also, given that the lube residue in my wash basin from the initially tarnished keycaps contaminated the new AEK keycaps, I guess that suggests that at least SOME of the lube came off in the dish soap/water bath. Have you had this problem before and ether was the only solution? Again thanks so much for your response -- I'm losing my mind over here!
« Reply #3 on: Fri, 01 June 2018, 07:08:15 »
You new guys are taking lubing to another level.
Offline chyros
  • a.k.a. Thomas
« Reply #4 on: Fri, 01 June 2018, 07:25:49 »
Ether isn't the same as petroleum ether ;) . Just use any apolar solvent; LPE, white spirit, turpentine, naphtha, etc.
Offline long_qt_pie
« Reply #5 on: Sat, 02 June 2018, 16:58:43 »
Maybe try toluene?  Find a friend that works in a wet chem lab and they should be able to help
Jetfire | Mech 27 v1 | Mira SE | Singa | Orion 2.5 | Eo87 | Lubrigante | MGA | IBM F XT | AEKII | Lightpad | Exent | Dolphin Rev 2 | F1-8x | Mr Suit
Offline jcoffin1981
« Reply #6 on: Sun, 03 June 2018, 23:53:48 »
For an easily accessible solvent try Ronsonol lighter fluid.
Offline glack23
« Reply #7 on: Mon, 04 June 2018, 10:59:12 »
ultrasonic cleaner?
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Mon, 04 June 2018, 11:11:09 »
I'd avoid toluene tbh, it's not very good for you.
Offline AuthenticDanger
« Reply #9 on: Mon, 04 June 2018, 11:48:22 »
Isopropyl Alcohol would be my go-to.
F Keys belong on the left.
Offline jcoffin1981
« Reply #10 on: Mon, 04 June 2018, 21:30:51 »
I have used lighter fluid to clean oils and greases from metals and synthetic jewels and it dissolves the intended solute.  I'm not a chemist so I don't know how krytox compares.  I have used it on switches before to clean lubed switches I no longer wanted lubed.
