Author Topic: GH60 PCB fits Pok3r II case?  (Read 2179 times)
Offline Pavilions
« on: Sat, 02 June 2018, 00:09:33 »
Does the GH60 PCB work with the Pok3r II keyboard case?
I have the keyboard but I damaged the PCB and I want to replace the whole switches to newer ones? (What do you recommend)?
Thanks
Offline elcubismo
    • Reddit page
Re: GH60 PCB fits Pok3r II case?
« Reply #1 on: Sat, 02 June 2018, 01:14:33 »
The original poker 2 or the usb-c version? If the original i dont see why it wouldn't since the poker basically set the standard for ansi/iso 60% keebs
Leopold FC660C lubed, silenced with landing pads | Norbatouch lubed, silenced with hyperspheres | Poker II MX Blue with vortex aluminum case, vortex red/white doubeshot pbt caps and o-rings | CODE TKL MX Clear with Miami | Unicomp Buckling Spring | GMMK with rainbow vomit switches, mostly jailhouse blues and pandealios
Offline Pavilions
« Reply #2 on: Sat, 02 June 2018, 02:03:51 »
Yes, The original Poker 2 not the USB-C
Thanks
