Author Topic: 85% back plate layout file  (Read 2739 times)
Offline delatroy
« on: Sat, 02 June 2018, 05:38:38 »
I want to get a custom backplate created and I don't want to mess up the dimensions.
Does anyone know where I can find a PDF, AI or DWG file of a standard 85% keyboard layout please?
Offline TalkingTree
    • My projects
Re: 85% back plate layout file
« Reply #1 on: Sat, 02 June 2018, 06:28:29 »
How does a 85% look like?
Offline Kilgarah
« Reply #2 on: Thu, 07 June 2018, 08:42:52 »
What is an 85%? If you know the layout, you can pop it into KLE and copy that into swillkb. It'll generate files for you.
Sent from my SM-G955U1 using Tapatalk
Offline whytwokay
« Reply #3 on: Fri, 08 June 2018, 20:08:37 »
I would think an 85% would look similar to a TKL or the Duck TC-V3?
