Author Topic: Can anyone identify this keyboard?  (Read 7047 times)
Offline themindrobber
« on: Sat, 02 June 2018, 15:35:47 »
Hi there,
I'm sorry if this is the wrong place to post but I'm hoping someone can help me identify the hardware seen below (fitting into an unrelated green casing) - image taken circa late 1980.
I would also be grateful if someone could enlighten me as to the meaning of the secondary set of characters above the normal QWERTY characters. I've seen them elsewhere but don't understand their significance.
Many thanks if you can help!
Gav
Offline Starius
Re: Can anyone identify this keyboard?
« Reply #1 on: Sat, 02 June 2018, 23:59:32 »
Looks like a prop from something out of Blake's 7 or Doctor Who, or some other sci-fi show out of the late 70s / early 80s.  (The lighting of the scene definitely looks like it was from that era of tv studio production.)
Where did you find it?
Offline Coreda
« Reply #2 on: Sun, 03 June 2018, 00:16:10 »
A Doctor Who prop it seems. Here's a thread discussing the possible base keyboard used and where the keycaps may have been sourced from.
From that topic it appears to be a Honeywell data conversion keyboard that had parts cut from the top and right (edit: looking again it's probably just due to the replacement keys extending over the white key area) and using replacement keycaps.
« Last Edit: Sun, 03 June 2018, 00:34:33 by Coreda »
Offline Starius
« Reply #3 on: Sun, 03 June 2018, 01:02:32 »
Oh cool, it was used in Logopolis.  That was Tom Baker's final story.
« Reply #4 on: Sun, 03 June 2018, 08:54:31 »
Thanks very much for pointing me to the other thread. I knew the television source material, it was the hardware I was specifically interested in. Much appreciated. :)
