Author Topic: [HELP] Cherry G80-0486 (low vintage switches)  (Read 2032 times)
Offline 27.9.2016
« on: Mon, 04 June 2018, 12:09:31 »
Hello
I found old Cherry keyboard with low type switches. Does somebody know how much is this worth?
If this is not worth much I am planing to desolder switches and make custom plate and connect all together using Tennsy.
Any other ideas?
More pictures: https://imgur.com/a/UBFoEPq
Offline ramblinrose
Re: [HELP] Cherry G80-0486 (low vintage switches)
« Reply #1 on: Mon, 04 June 2018, 15:28:24 »
Looks like cherry M8 switches, I had an epson laptop that used them, as well as gorgeous brown keycaps like that. I do not think there are worth a ton as the caps arn't compatible with standard MX. I think they use a different pin layout too.
