Author Topic: lite on sk-0002  (Read 2920 times)
Offline sexzual
lite on sk-0002
« on: Mon, 04 June 2018, 18:00:57 »
got a lite on sk-0002 in without a cord.  hoping someone has one they can trace the cable on and tell me what the pinout is so i can wire it up to either ps2 or soarers converter.  anyone?
Offline ag36
Re: lite on sk-0002
« Reply #1 on: Mon, 04 June 2018, 19:40:16 »
Have you got multimeter?
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline sexzual
Re: lite on sk-0002
« Reply #2 on: Mon, 04 June 2018, 20:19:11 »
sure do.  a few flukes
Offline ag36
Re: lite on sk-0002
« Reply #3 on: Tue, 05 June 2018, 07:51:10 »
As for ps/2, put in AT mode. Get a ps/2 extension lead and cut one of the connector.
Measure 5v and ground then you have data and clock left, the rest should be easy.
Pinout diagram for ps/2
https://en.wikipedia.org/wiki/PS/2_port
« Last Edit: Tue, 05 June 2018, 07:55:25 by ag36 »
Offline ramblinrose
Re: lite on sk-0002
« Reply #4 on: Tue, 05 June 2018, 08:02:20 »
I've got this keyboard - the cable it comes with is the larger 5-pin DIN end. Works with a standard din->ps/2 converter. Hope that helps!
Offline sexzual
Re: lite on sk-0002
« Reply #5 on: Tue, 05 June 2018, 14:43:25 »
ramblinrose, can you trace the wires of the din connector and let me know which pins on the keyboard are gnd, vcc, clock, and data?  would be forever grateful!
Offline sexzual
Re: lite on sk-0002
« Reply #6 on: Tue, 05 June 2018, 20:31:13 »
anyone else have this keyboard and can help me out?  unfortunately ramblin doesn't have a multimeter
Offline ramblinrose
Re: lite on sk-0002
« Reply #7 on: Wed, 06 June 2018, 11:36:18 »
I'm useless!  :-\   Good luck fixing the cable - it's a nice keyboard, I used mine at work for a week but it was too loud hah.
Offline sexzual
Re: lite on sk-0002
« Reply #8 on: Wed, 06 June 2018, 14:34:00 »
haha thanks.  it's in great shape besides missing the cable.  someone else has to have one of these boards
Offline ag36
Offline sexzual
Re: lite on sk-0002
« Reply #10 on: Wed, 06 June 2018, 14:49:43 »
thanks, but doesn't help when there is no cable at all.  only have a header on the keyboard circuit board.  hence why i need someone to trace the pins.
Offline ag36
Re: lite on sk-0002
« Reply #11 on: Wed, 06 June 2018, 16:04:37 »
Ah, I see. Maybe post some photos of the pcb from the top and bottom and someone might be able to read the circuit for you?  Just follow the capacitors and diodes and you'll find negative and positive. Follow crystal to find clock.
« Last Edit: Wed, 06 June 2018, 16:06:35 by ag36 »
Offline sexzual
Re: lite on sk-0002
« Reply #12 on: Fri, 15 June 2018, 20:09:36 »
i took an educated guess and was right on the first try.
gray (top) is ground
brown (3rd down) is vcc
yellow (4th down) is clock
red (5th down) is data
for future reference
