Author Topic: What's the best way to get a Tada68 with Zealios?  (Read 2598 times)
Offline Draculala
« on: Mon, 04 June 2018, 22:57:07 »
I'm interested in the Tada68 or similar 65% keyboards. I also want to try zealios switches. On KBDFans website, I can get it for $140. However if I order from Taobao, I can get the version with Bluetooth and cherry switches for $75 and then buy zealios switches seperately. I could then desolder the cherry switches and sell them and end up with Zealios Tada68 with Bluetooth that is cheaper than on KBDFans.
I'm wondering if there is a quality difference between the KBDFans Tada68 and the one on Taobao. Is there anything I should be aware of? Is this a good idea or should I just save up and buy it straight from KBDFans?
Link for Taobao:
https://item.taobao.com/item.htm?spm=a230r.1.14.15.20c32b2ejkpZuU&id=561384714316&ns=1&abbucket=3#detail
Offline Harms
Re: What's the best way to get a Tada68 with Zealios?
« Reply #1 on: Mon, 04 June 2018, 23:13:16 »
Going through Taobao would be a hassle unless you have a proxy and stuff.
They would be the same either way though.
Therefore, I would personally recommend getting it from KBDfans.
It would be much easier.
Offline Draculala
« Reply #2 on: Mon, 04 June 2018, 23:17:07 »
I believe that Taobao ships to North America directly so I won't have to use a proxy. If they are the same then I wonder why one costs more than the other while offering less features.
Offline Harms
« Reply #3 on: Tue, 05 June 2018, 00:52:11 »
Hmm my mistake. I failed to look at the taobao page properly.
Anyways, I beleive the Taobao Tada68 that you listed is bluetooth.  :)
Offline Kevadu
« Reply #4 on: Tue, 05 June 2018, 01:22:23 »
Although it's honestly hard to tell from the pics that Taobao one could easily be the plastic case version of the Tada68.  That's the price it usually goes for.  While I don't think plastic cases are necessarily a bad thing that's also probably why it's cheaper.  The one you usually see on KBDFans is aluminum.
Offline Harms
« Reply #5 on: Tue, 05 June 2018, 02:13:49 »
Yea great suggestion. To add on to that, Bluetooth keyboards are usually plastic because transmitting a Bluetooth signal through aluminum is tough.
Therefore, that Bluetooth one on taobao may be plastic as suggested.
