Author Topic: [Solved]PS/2 to usb for trackpoiont on M13?  (Read 2140 times)
Offline ag36
« on: Tue, 05 June 2018, 11:00:52 »
I am restoring a maxiswitch M13, the keyboards works fine with blue cube but trackpoint don't, does anyone know which converter works?
Thanks.
Edit: solved, keyboard is now near restored just waiting for tracking point caps.
« Last Edit: Thu, 07 June 2018, 17:48:29 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline Techno Trousers
  • ʘ_ಠ
Re: PS/2 to usb for trackpoiont on M13?
« Reply #1 on: Tue, 05 June 2018, 11:10:11 »
I've used the Belkin F5U119-E adapter with good results. It's a Y-adapter that takes both PS/2 inputs and has a single USB output.
Offline ag36
« Reply #2 on: Wed, 06 June 2018, 06:04:00 »
I've used the  adapter with good results. It's a Y-adapter that takes both PS/2 inputs and has a single USB output.
Thanks, but.
Belkin F5U119-E seems to be discontinued :(.
« Last Edit: Wed, 06 June 2018, 06:07:56 by ag36 »
Offline ag36
« Reply #3 on: Thu, 07 June 2018, 14:25:46 »
