Author Topic: [IC] GMK >Terminal_ R2 GB NOW LIVE  (Read 35544 times)
Offline elfick
  • Can I get Colemak and a side of fries with that?
Re: [IC] GMK >Terminal_ R2
« Reply #50 on: Fri, 08 June 2018, 11:00:10 »
Suggestions?
On another note, the #! I know from shell scripts, but what is the :~$? Is it a terminal prompt?
The ~ usually signifies the home directory and $ signifies a non-root user.
I'm not familiar with a common usage for the colon so maybe it was just supposed to be an emoticon?
Or possibly the lack of data before the colon would signify the local host since that is often what comes before the path.
Offline wholypantalones
  • text and icon mods plz.
« Reply #51 on: Fri, 08 June 2018, 11:20:22 »
Suggestions?
I like the #! better than the :~$ but either or, imho. Might be something worth polling.
Based on feedback I think Im going in that direction.
Would (1) each in 1.5u, SUPER and CODE suffice? Or does we require 2? Trying to keep the cost down. I think removing the :~$ key is a good idea.
Can we have the code keys back for the 1u OS keys in the tsangen kit and maybe the 1.5u mods instead of the ~:$ thing?
I tend to favor uniformity, so either 2 CODE/SUPER keys in 1.5 and 1u would be optimal.
Offline Arithmetics
« Reply #52 on: Fri, 08 June 2018, 13:16:24 »
im in
Offline deterouni
« Reply #53 on: Fri, 08 June 2018, 13:22:26 »
Really excited for this buy. Kicked myself for missing R1.
Offline giangtran19x
« Reply #54 on: Fri, 08 June 2018, 13:26:07 »
Looking great. Definitely interested.
Offline zap2oz
« Reply #55 on: Sat, 09 June 2018, 22:17:31 »
Definitely in for at least one set!
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #56 on: Sat, 09 June 2018, 22:44:20 »
Yea, I might be in for a set Terminal
Offline kyoumau
« Reply #57 on: Sat, 09 June 2018, 22:46:45 »
This looks great :D
Offline midnight2903
« Reply #58 on: Mon, 11 June 2018, 01:56:10 »
I waited one whole year for this, LETS GOOOO!!!
Offline Giorgio
« Reply #59 on: Mon, 11 June 2018, 02:53:59 »
nice!
Offline oh_chesteroni
« Reply #60 on: Tue, 12 June 2018, 10:33:32 »
Any updates? I've got a terminal R2 sized wad of cash burning a hole in my pocket.
Offline mtuanvu
« Reply #61 on: Tue, 12 June 2018, 11:17:43 »
Count me in...
Offline TheKeyCompany
  • Because You Need the Feels...
    • The Key Dot Company
« Reply #62 on: Tue, 12 June 2018, 11:18:57 »
Updated mock ups here
Ill add this to the post as well.
Changes are called out in the mockups in the album
Re: [IC] GMK >Terminal_ R2 Kits Updated 6/12/18
« Reply #63 on: Tue, 12 June 2018, 13:11:09 »
Looks good! I'm gonna have to get me one of each kit except the ergodox :)
Why were the 1.5u :-$ replaced with blanks and not #!?
« Reply #64 on: Tue, 12 June 2018, 13:28:35 »
Anyone else want #! on the 1.5u instead of blank in the base kit?
Offline xondat
  • i'm not a star
« Reply #65 on: Tue, 12 June 2018, 13:31:54 »
Do 2.25/2.75u convex moulds finally exist?
« Reply #66 on: Tue, 12 June 2018, 13:45:03 »
How about just code keys instead of hashbangs and Mr. terminalface.
« Reply #67 on: Tue, 12 June 2018, 15:15:48 »
It doesn't matter all that much to me whether the 1.5u mods are replaced with #!, :-$, or code as long as the base color is black. I think the AE blank mods in the base kit currently disturb the homogeneity of an all black base color bottom row. You could place those mods into the AE kit with whatever legend you decide to us.
Offline elfick
« Reply #68 on: Tue, 12 June 2018, 18:19:16 »
#! would be awesome!
« Reply #69 on: Tue, 12 June 2018, 18:28:32 »
In the interest of keeping it simple, I shall replace the 1.5u AE blanks with N9 1.5u #!
« Reply #70 on: Tue, 12 June 2018, 18:37:34 »
:thumb:
Looking forward to the GB!
« Reply #71 on: Tue, 12 June 2018, 19:28:50 »
[/quote]
Waiting to find out from GMK.
Offline Vigrith
« Reply #72 on: Tue, 12 June 2018, 20:22:48 »
They don't exist, I had Oblotzky confirm this with CK from GMK as I really want those keys to be a thing myself - they don't own the moulds for that, nor 1.25 convex, but I'd assume they may potentially be interested in making that happen if someone's willing to front the dosh for the first set. Christopher was on holiday at the time when they spoke to him about that though so we don't know the cost nor the actual feasibility in having them made.
Offline Giorgio
« Reply #73 on: Wed, 13 June 2018, 02:24:52 »
Some legends are really ugly.
They seem like an insult. Please replace them with something normal.
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #74 on: Wed, 13 June 2018, 02:48:43 »
So basically make terminal not terminal? Okay....
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline Giorgio
« Reply #75 on: Wed, 13 June 2018, 03:25:38 »
They're ugly. And not necessarily terminalesque.
« Reply #76 on: Wed, 13 June 2018, 08:53:36 »
Base kit updated. (Imgur album updated in post) Removed AE 1.5u mod keys, replaced with N9 #! keys.
GMK confirmed that R4C 2.25u and 2.75u keys are NOT available. I am working with them to see what it will take to get them made. Perhaps Terminal R2 will be the first to offer them!
Re: [IC] GMK >Terminal_ R2 Kits Updated 6/13/18 Waiting on Pricing
« Reply #77 on: Wed, 13 June 2018, 09:01:36 »
Is the green >_ separated from base kit? That's a bummer... Felt like the green >_ and enter really made the R1 kit.
« Reply #78 on: Wed, 13 June 2018, 09:07:04 »
Theres a green Esc key. I could possibly swap them from AE to base. Anyone else have input on that?
Offline Vigrith
« Reply #79 on: Wed, 13 June 2018, 09:12:20 »
That'd be fantastic, if you do maybe try and look into getting 1.25 (if you aren't already) made as well since that's also needed for most split space builds!
Offline Vigrith
« Reply #80 on: Wed, 13 June 2018, 11:13:47 »
Edit: Post no longer relevant without Giorgio's polution that has been cleaned up by mods.
« Last Edit: Wed, 13 June 2018, 17:14:28 by Vigrith »
Offline chuckdee
« Reply #81 on: Wed, 13 June 2018, 15:45:45 »
Can you add an extra 2U to either the 40s or Spacebar kits?
« Reply #82 on: Wed, 13 June 2018, 17:03:29 »
For which board? What profile? What did I miss?
Offline chuckdee
« Reply #83 on: Wed, 13 June 2018, 17:43:24 »
Ive taken to the symmetrical layout on the Clueboard with split 2u space.  If you can't do it, I understand - my choice in layout.  But I've been able to get it in a few GMK sets, so figured that I would ask. I'm in either way.
« Reply #84 on: Wed, 13 June 2018, 18:02:08 »
You have options: You could get the spacebar kit and the 40 kit, then you'd have (2) 2u spacebars. That or use the 2u shift keys from the base and AE kit. Or theres always r/mm!
Im doing my best to get everyone what they want while keeping it affordable. Sorry youre not getting exactly what you want, but at least you can still fill out the board!
Offline chuckdee
« Reply #85 on: Wed, 13 June 2018, 20:04:36 »
As I said, no worries.  I'll just have to see how the prices shake out.  Thanks anyway!
Offline Hamel
  • KBDLAB
« Reply #86 on: Wed, 13 June 2018, 20:38:44 »
Super excited for this.
Offline kim-kim
« Reply #87 on: Thu, 14 June 2018, 02:56:56 »
In the 40s kit, I think it might be worth swapping the profiles on the 1u tab and 1u esc. The default planck/Preonic layouts have tab on r2 and escape on r3.
That aside, I’m interested but may not pick up a kit due to the sheer number of GMK sets being run right now
+1 this
And with recent update, I must buy more kits than expected :'(
Offline rfindra
« Reply #88 on: Thu, 14 June 2018, 07:28:50 »
Yes please!!!
Offline stu-rem
« Reply #89 on: Fri, 15 June 2018, 02:57:51 »
Suggestions?
Could be. From ssh/scp host:path ...; or
<digression>
The : as a command (whitespace separated from the next word) indicates this pipeline is parsed but not executed, up to end-of-line or ; terminator (so, syntax must be okay including balanced parentheses etc or you'll get an error.) Can be useful to start shell prompts, like:
: \u@\h \p \$? ;
Effectively you can terminate the "comment command" at the semicolon; the next words are parsed and executed as your "normal" typed command.
So, why? Imagine a terminal session, cmds scrolled up the window; tripple-click any cmdline to select, just paste the whole thing, or multiples. The prompts are isolated and ignored, but not the commands.
As does   ;: \u@\h \p \$? ;
; login :  is similar but different ;-)
For similar copy+paste reasons, root's default PS2="> " is an early Unix mistake; just begging to overwrite some file someday, with an output redirection via accidental paste.
Try PS2="  " just to indent a bit, sans side-effects.
</digression>
<TL ; DR>  :-)
I'd go with  #!  (or code, meta, super, ...)
Sent from my SM-N9005 using Tapatalk
« Last Edit: Fri, 15 June 2018, 02:59:47 by stu-rem »
Offline Giorgio
« Reply #90 on: Fri, 15 June 2018, 04:08:40 »
Thanks for erasing relevant posts.
Offline chuckdee
« Reply #91 on: Fri, 15 June 2018, 09:57:18 »
Did he erase them?  I thought it was the mods... >.>
Offline TerryMathews
« Reply #92 on: Tue, 19 June 2018, 09:32:58 »
Maybe when Giorgio is involved, we should all be mods.  :eek:
Offline Giorgio
« Reply #93 on: Tue, 19 June 2018, 10:27:32 »
I know the truth.
Offline chuckdee
« Reply #94 on: Tue, 19 June 2018, 11:10:56 »
I know the truth.
Offline HFoletto
« Reply #95 on: Tue, 19 June 2018, 13:28:51 »
Yes please!!!
+1
Offline sheepish.alpaca
Re: [IC] GMK &gt;Terminal_ R2 Kits Updated 6/13/18 Waiting on Pricing
« Reply #96 on: Tue, 19 June 2018, 13:37:57 »
Not quite sure what you’re asking here - are you saying that you’d swap the base and legend colors for both the Esc key (AE base, N9 legend) and >_ (N9 base, AE legend) keys, or just swap the base and legend colors for the >_ key?
« Reply #97 on: Tue, 19 June 2018, 20:45:17 »
From my understanding, it's just removing the green >_ key from AE kit and adding it to base. At least that's what I originally wanted/suggested.
Re: [IC] GMK >Terminal_ R2 PREVIEW POSTED Goes Live June 27, 2018
« Reply #98 on: Fri, 22 June 2018, 11:39:42 »
Full product preview is now available. No more changes will be made.
Product Preview
Offline chuckdee
« Reply #99 on: Fri, 22 June 2018, 12:03:13 »
What are the sizes on the 40s Space bars?  Just curious to make sure that the r4c was the only 2u in that?  Thanks!
