Author Topic: deleted  (Read 2858 times)
Offline wowremy
deleted
« on: Fri, 08 June 2018, 22:02:52 »
Please delete
« Last Edit: Thu, 14 June 2018, 15:34:45 by wowremy »
Offline Kevadu
Re: They warned me this was an expensive hobby.
« Reply #1 on: Fri, 08 June 2018, 23:01:10 »
Honestly you really don't need a solder station that fancy.  A cheap soldering iron is fine, so long as it has some sort of temperature control.
Offline wowremy
« Reply #2 on: Fri, 08 June 2018, 23:35:42 »
I know the fan is overkill. But then I looked at the 6 keyboard kits in my receipts and thought, "why not dude"
Offline FrostyToast
  • Litshoard
« Reply #3 on: Fri, 08 June 2018, 23:44:08 »
I've had some recommend this one as well for a solder sucker. Never owned it myself though.
As for the soldering station, I really can't see anyone going for anything less than a Hakko.
A station that likely won't burn your board or your hands is going to run $50, so just go that extra little bit to ensure that the things which are way more expensive than your soldering station are in good hands.
Quote from: elton5354
Offline ag36
« Reply #4 on: Sat, 09 June 2018, 09:46:45 »
I got a fume extractor and $400 weller iron for synthesizer kit, overkill for keyboards  ;D
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline T14
« Reply #5 on: Tue, 12 June 2018, 15:50:11 »
Tools are fun, and make projects enjoyable to see through to the end.
DIY is rarely cheap, as it is hard to compete with the economies of scale in mass production.
Revel in it, and take pride in your makerspace, however it is kitted out  :thumb:
Autocorrect is my worst enema.
