Author Topic: Wireless tenkeyless mechanical keyboard  (Read 4978 times)
Offline ChoJo
« on: Tue, 12 June 2018, 12:41:23 »
Hi eveyrone,
I'm on the market for a tenkeyless wireless keyboard.
I currently own a Realforce keyboard, but I moved to another place and want less cable on my desk.
Any recommandation?
Offline brianjking
  • always carry a towel.
    • @brianjking
Re: Wireless tenkeyless mechanical keyboard
« Reply #1 on: Thu, 21 June 2018, 15:02:12 »
The choices are rather limited. I know you're looking for a TKL but I'll start off with saying I first started off with adding a Hasu BT controller to a Type-S and a HHKB JP. I've since moved to having 2 HHKB BT (factory Bluetooth models).
The Plum NIZ models below are Bluetooth 4.0 and reasonable price, neither are TKL though. Perhaps the 75% (Plum 84) would work well for you. I know Plum has a TKL model in both the Topre clone and Gateron switches, however, as far as I'm aware no Bluetooth version of this as of yet. I might pickup one of the Plum 84's at some point in the future, I do wish they'd stop using wonky spacebar sizes though.
There's also a few other options but I don't have much (or any) experience with them:
Anyway, best of luck and I hope this helps!
Offline moh18one
« Reply #2 on: Thu, 21 June 2018, 16:04:35 »
Topre planned to release a BT keyboard but no date atm. There is the Varmilo VB87M
Offline brianjking
    • @brianjking
« Reply #3 on: Thu, 21 June 2018, 21:17:51 »
Outside of the HHKB BT? Clearly that already exists...
Have a source on this info?
