Author Topic: MX Black PCBs for Harvest $20 shipped CONUS  (Read 79373 times)
Offline TheKeyCompany
  • Because You Need the Feels...
    • The Key Dot Company
« on: Fri, 15 June 2018, 14:07:34 »
MX Black PCBs for Harvest at TKC
Not sure if this is the right category for this.
$20
These are in stock and ship immediately.
Used G80-1800 PCBs with MX Blacks. Not "vintage" as the boards had USB cables. However, theyre worn in and DIRT CHEAP.
MXBLACKS code at checkout for free CONUS shipping.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: MX Black PCBs for Harvest $20 shipped CONUS
« Reply #1 on: Fri, 15 June 2018, 16:31:07 »
Now I need to order a desoldering iron. Is there one that you recommend?
Sent from my SM-G950U using Tapatalk
« Reply #2 on: Fri, 15 June 2018, 17:35:54 »
Honestly, I don’t mind using my Hakko Iron and this thing:
https://www.amazon.com/dp/B00LNAYBO2/ref=cm_sw_r_cp_api_F7djBbNM58HPB
Don’t buy the cheap version, get the Hakko!
As far as automatic gun type ones I had a China version I it on eBay, the tip broke pretty quick and the replacements I ordered don’t fit. So YMMV.
Or drop $280 on the Hakko
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Fri, 15 June 2018, 19:18:26 »
Just ordered me one, awesome deal you guys got here with these broken PCBS! They may not be true vintage blacks, but I suspect 90% of the smoothness with vints comes from just being well broke in TBH. So I doubt there is a huge difference between them & these. :thumb:
I've had pretty good results using one of these cheap de-soldering irons, https://www.amazon.com/gp/product/B00068IJSG/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1. The only gripes I would have against it is it doesn't have temp control & the tips wear out pretty quick. Thankfully they are replaceable & not too expensive for replacements. That said as with any product YMMV with one of these vs a sodapullt.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #4 on: Fri, 15 June 2018, 19:51:46 »
Thanks, that's actually the one I was going to order a few months ago.
Was planning on hooking it up ti my wlc100 to get some sort of temp control.
