Author Topic: Weird Model M key - spring won't buckle  (Read 2976 times)
Offline Half-Saint
« on: Tue, 20 April 2010, 14:38:38 »
I bought a blank set of 2-piece keys for my Ambra keyboard. All is fine except for one weird key. It looks virtually the same as all the rest with one difference. When I push it, the spring doesn't buckle properly and there's virtually no click. Any ideas on what to do? I know it's not the problem with the spring because it does that no matter where I place the key.
Cheers
SainT
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline ch_123
« Reply #1 on: Tue, 20 April 2010, 14:42:59 »
When you put the key on, did you make sure to hold the keyboard upside-down whilst reinserting it?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2 on: Tue, 20 April 2010, 14:44:06 »
Keyboard upside down?
I'd recommend tilting it back (such that the front is raised and spring leans away from you) but not upside down...
kishy.ca
Offline ch_123
« Reply #3 on: Tue, 20 April 2010, 14:53:41 »
Well, upside down makes sure the spring lies along the top of the barrel, which I find to be the optimal angle for making it fit right.
If anyone says "That's what she said"...
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Tue, 20 April 2010, 14:59:24 »
That's what he said to her when she just didn't get it.
kishy.ca
Offline Half-Saint
« Reply #5 on: Tue, 20 April 2010, 15:20:00 »
Believe me, I just finished inserting 101 keys... they all function properly, except the one I told you about. Will try again but I think there has to be a difference between keys!
[SIGPIC][/SIGPIC]
Offline brkz
« Reply #6 on: Tue, 20 April 2010, 15:20:26 »
Sometimes just taking the key cap off and reseating it a few times will make it work right even if nothing else changed. Press the key a few dozen times too, sometimes they won't seat properly right away but clear up with excercise.
Offline Mental Hobbit
« Reply #7 on: Tue, 20 April 2010, 16:30:35 »
Put the offending key and a working one side by side and eyeball them carefully in bright light. Could be just some lint.
Typing on blues.
Offline Half-Saint
« Reply #8 on: Wed, 21 April 2010, 01:41:04 »
Inside of the stem is not all nice and smooth. I tried hacking at it with a small screwdriver but can't get it as smooth as the rest and I don't have a file... I'll try again after work.
[SIGPIC][/SIGPIC]
