Author Topic: Do Signature Plastics 7u SA spacebars have 4 stems?  (Read 3542 times)
Offline lemur
  • personal text
« on: Fri, 22 June 2018, 18:28:46 »
I have a Maxkey 7U SA profile spacebar I am using and I want to know if the ones Signature Plastics produces are the same when it comes to stem placement..
A board I am using uses 6U stabilizers, but fits a 7U spacebar thanks to the fact the maxkeys one has 4 different mounting stems.. one of which for the 6U stab
Does anyone with a 7U SP SA profile spacebar know if they are the same as this Maxkeys one below?
« Last Edit: Fri, 22 June 2018, 18:32:28 by lemur »
keyboards
Offline user 18
Re: Do Signature Plastics 7u SA spacebars have 4 stems?
« Reply #1 on: Fri, 22 June 2018, 18:47:26 »
I have a 7u spacebar from Hack'd which only has three stems -- center and two edges. It's possible that SP also has a 4-stem version, but I don't have one.
Avatar by ashdenej
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Sat, 23 June 2018, 01:02:33 »
I believe they all have 3.
Sent from my mobile using Tapatalk
