Author Topic: GMK "B" Key Legend  (Read 7436 times)
Offline Kavik
GMK "B" Key Legend
« on: Fri, 22 June 2018, 21:44:59 »
I just received GMK Dark Solarized, and the legend on the B key is every so slightly crooked. Is GMK's mold screwed up? Is this a common issue with GMK sets?
Some of the number keys' legends also look a little wonky.
Re: GMK "B" Key Legend
« Reply #1 on: Fri, 22 June 2018, 21:48:00 »
May be they're fake.
Offline Giorgio
« Reply #2 on: Sat, 23 June 2018, 00:55:06 »
Maybe they're [.b]ake
« Reply #3 on: Sat, 23 June 2018, 22:32:59 »
check the T key as well
this has been an issue with GMK for a while
Offline Kavik
« Reply #4 on: Sat, 23 June 2018, 23:41:05 »
I doubt it's fake. I got it directly from Keyclack through the GB.
I think the T key is also slightly crooked, but it's harder to tell. Z also appears to be crooked.
Is this something that affects entire runs of a keyset, or is it just a per person occurrence, or is every GMK set like this? This is my first GMK set, hence my ignorance. It seems weird if not all sets are affected unless they have multiple sets of molds.
I know it's nitpicky.
Offline nogoodnames444
  • I like keyboards
« Reply #5 on: Sun, 24 June 2018, 00:16:51 »
It might just be inconsistencies with the mold there is issues like that on a lot of gmk sets
« Reply #6 on: Sun, 24 June 2018, 13:10:26 »
my oco classic beige w/ blue set from 2013 had the same issues
that's just how it is with GMK
my suspicion is that they mold in 4s, and one of the 4 plates is slightly crooked
curious to see if this holds up on OG sets
more research needed
Offline lemur
  • personal text
« Reply #7 on: Sun, 24 June 2018, 22:02:10 »
I have an 'OG' set on a keyboard with a 2003 datecode and it appears that the B and T is ever so slightly crooked.. I doubt I'd notice if someone didn't point it out. But I do perceive it slightly..  with both rotated a tiny bit clockwise.
This is not seen from a GMK set from within the past year.
keyboards
« Reply #8 on: Sun, 24 June 2018, 22:15:39 »
My GMK soware has it, and I've seen it on nautilus sets.
Offline lemur
  • personal text
« Reply #9 on: Sun, 24 June 2018, 22:44:58 »
from a cherry keyboard with a 2003 datecode..
decide for yourself if you see it?
198641-0
keyboards
« Reply #10 on: Sun, 24 June 2018, 23:27:18 »
it's not on every set, i think 1 out of every 3-4 has at least one of the defects
