Author Topic: DZ60 only works on one pc  (Read 2900 times)
Offline 8BitDuck
« on: Mon, 25 June 2018, 06:01:26 »
Hi all.
Just built my first keyboard using a DZ60, got it programmed and it works fine on my home PC, but when I tried to use it at work it just dosn't register, all I get is a 'Unknown USB Devise (Device Descriptor Request Failed)'.
Has anybody else had an issue like this and know a fix?
Apologies if I've posted this in the wrong place, this is also my first forum post
Thanks
« Last Edit: Mon, 25 June 2018, 06:23:15 by 8BitDuck »
Offline donut_sauce
Re: DZ60 only works on one pc
« Reply #1 on: Mon, 25 June 2018, 07:56:45 »
I’ve never had this issue my dz60s, they all work fine on other computers.
Offline kakan
« Reply #2 on: Mon, 25 June 2018, 12:57:37 »
Have you tried uninstalling the device on that computer from the device manager and plugging it back in?
Offline Kavik
« Reply #3 on: Mon, 25 June 2018, 16:17:35 »
I sometimes have issues with my KBP V80 and MOON (Kimera controller) if I plug them into a new computer or into a different USB port.
Something that usually works for me is rebooting with the keyboard plugged in so that the BIOS/UEFI initializes it. Sometimes I just have to wait several minutes for Windows to find the driver though.
Offline 8BitDuck
« Reply #4 on: Tue, 26 June 2018, 07:40:58 »
Thanks for the suggestions, I tried pretty much everything.
Finally got to the bottom of it, turns out the cable was buggered.
Offline lasernasaur
« Reply #5 on: Tue, 26 June 2018, 22:35:43 »
nice. i was worried about buying the DZ60 for my next project, but glad it was just the cable. Congrats on figuring out the problem.
