Author Topic: closed [Pre-Order] MOYAN 96 Mechanical Keyboard Kit  (Read 16903 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Mon, 25 June 2018, 22:20:28 »
Moyan 96% Custom Keyboard Kit
ORDER LINK
Expiration Date: 31st July 2018 (EST time)
Estimated Ship Date: Nov 2018
Total Weight: About 5kg
Shipping Method:Free shipping with FedEx ,DHL or SF-express
Custom Duties: Depends on your country's custom policy
If you choose with Switches Editon, you will receive an assembled one.
Spec
Inspired by lava bursting and melting rock.
five-axis CNC processing aluminum case
providing red and dark blue case version for choosing.
96% layout(Can't be programmed)
Up to 136 RGB beads and colored acrylic providing uniform crack lighting
colored acrylic using mirror surface processing ensuring the whole design sense even without lit up
Magnetic data interface and customized cable fitting the cracking design and providing longer service life
Bright polished copper Logo grinding by a special technique
Carbon plates supporting by 7 positioning screws
Programmed three lights on ESC key
partition multi-color adjustment all key RGB lighting
Adjustable crack light to two Default color
« Last Edit: Mon, 13 August 2018, 02:48:54 by KPrepublic »
