Author Topic: Question: O-Ring for Razer Chroma V2 Yellow Switch  (Read 2931 times)
Offline MithosX
« on: Sun, 01 July 2018, 12:47:47 »
Hi guys,
So I recently bought a BlackWidow Chroma V2 with Yellow Switches, I actually bought the orange one as well but returned it cuz the yellows felt a lot smoother. Now I do like the responsiveness of the yellow switches (which are Speed/Silver Cherry switches), but I was wondering if anyone has a suggestion for O-Rings to reduce the travel  by a bit. I know most O-Rings are used to reduce noise but that doesnt bother me too much, although when I buy O-Rings to reduce travel distance, the sound will probably also reduce.
I live in The Netherlands and I have yet to find a Dutch website that sells O-Rings for mechanical keyboards, so I will probably have to import them from somewhere, that why I am asking this, to get it right the first time!
Thank you!
« Last Edit: Sun, 01 July 2018, 19:48:30 by MithosX »
Offline nogoodnames444
  • I like keyboards
Re: Question: O-Ring for Razer Chroma V2 Yellow Switch
« Reply #1 on: Sun, 01 July 2018, 18:20:44 »
o rings will make your keys feel mushy
Offline MithosX
« Reply #2 on: Sun, 01 July 2018, 21:10:40 »
Yeah I thought so. I found a shop that sells O-rings with Blue (A50) and Black (A40). However when I look at other webshops in the USA their Blues are always softer than their Blacks, usually Blue =A40 and Black = A50. Is the webshop making a mistake stating Blue = A50 and Black = A40. Or is the color of the O-rings not a universal standard when measuring Hardness?
« Last Edit: Sun, 01 July 2018, 21:12:11 by MithosX »
  • I like keyboards
« Reply #3 on: Mon, 02 July 2018, 12:00:01 »
It might be mistake but it might now I wouldn't know
