Author Topic: Mousepad Roundup at Engadget  (Read 3066 times)
Offline itlnstln
« on: Wed, 21 April 2010, 09:27:11 »
Check it if you're interested.
Offline Rajagra
« Reply #1 on: Wed, 21 April 2010, 10:32:54 »
This one's a win even if it isn't the best performing:
Offline smuvmoney
« Reply #2 on: Wed, 21 April 2010, 11:09:49 »
Ripster, I have to ask - where did you get that eye-bee-M mousepad?
Offline ch_123
« Reply #3 on: Wed, 21 April 2010, 11:12:29 »
They were on eBay recently, altough I think the guy is all sold out now.
Offline maclover
« Reply #4 on: Wed, 21 April 2010, 12:46:05 »
Don't forget to get a carpal tunnel glove to minimize friction between your skin and your desk or mouse pad for that extra smooth pro gaming experience.
Offline Rajagra
« Reply #5 on: Wed, 21 April 2010, 14:11:38 »
Wow, he has that big-ass mat and still needs to keep lifting the mouse (judging by how often his hand movement is NOT matched by screen movement.) Low sensitivity players are a strange bunch.
Offline Arc'xer
« Reply #6 on: Wed, 21 April 2010, 14:56:03 »
Quote from: Rajagra;174177
Surprisingly this guy uses double the amount at 100cm/360 at around half the video, over mew's 55cm/360; and he doesn't lift it as much.
Offline Bullveyr
« Reply #7 on: Thu, 22 April 2010, 07:36:13 »
W:ET might be pretty fast and has a lot of movement but it's no Q3?
Play-Style is also a factor, unfortunately you can't really see what's going on on the screen in the BossHK vid.
When it comes to mousepads, trust your cat.
Reminds me that I wanted to buy some new clothpads.
Quote from: ripster;185750
Mechanical switches are mechanical.
Offline NOMiS
    • http://teamvga.com
« Reply #8 on: Thu, 22 April 2010, 09:28:34 »
As usual Tom's hardware sucks. Just a bunch of filler and stuff I could find out from reading the box put on 21 pages.
Steelseries Xai
Poker X KBC (Red)
