Author Topic: [IC] Doppio - 80% Custom Keyboard Kit (white color sample pics updated)  (Read 64205 times)
Offline PlayKeyboardTW
    • Shop
Re: [IC] Doppio - 80% Custom Keyboard Kit (white color updated)
« Reply #100 on: Sat, 28 July 2018, 11:21:44 »
White looks great but I would also be interested in a more matte finish.
Also quick question on the design, is the case/plate is a top mount and is it a high profile where the bottom of the keycaps are hidden? The initial renders make it seem as if they are exposed.
Top mounting is right.
The bottom of keycaps are a bit exposed as you can check photos in prototype album.
We limited the height of front edge to be around 20mm. If it's too high, it might be a bit uncomfortable when typing. ;)
Offline floris
« Reply #101 on: Sun, 29 July 2018, 01:39:09 »
How scratch resistant is the white finish?
    • Shop
« Reply #102 on: Sun, 29 July 2018, 04:38:12 »
Normal hand nail won't do damage on it. I don't know about other sharp stuffs but you certainly won't want to make them near your keyboard. :p
We all do a impact test to see how it goes comparing to anodize finish.
Offline darthzero
« Reply #103 on: Tue, 31 July 2018, 01:53:53 »
I saw this thread when the first renders were up and i felt it was kinda "meh", now as i come by just by accident (browsing gh that is^^) it went up to "must buy". Good job!
May i ask what color is presented in the first picture, the link says silver so i'm unsure what to select.
Also, may i suggest an option to add on the Polycarbonate bottom plate (instead of only being able to choose between Aluminum and Polycarbonate), extra switch plates and extra PCBs?
Thank you for your time.
Discord: kuno#0600
Reddit: u/darthzero
    • Shop
« Reply #104 on: Tue, 31 July 2018, 05:25:21 »
Hi. The pic you mentioned is silver which we set it as a color option till white came up.
The case with a gold plate is white I think (can't really recall it).
We'll put some new renders in product page when the GB is about to start.
Surly you will be able to buy extra parts. It's just a bit complicated to put them all in the same page.
We are still doing a research for it. :p
Thanks for seeing our improvement. :thumb:
    • Shop
« Reply #105 on: Wed, 01 August 2018, 20:09:17 »
Guys, more renders are up. :p
You will be able to see all case others and all plate colors in these pics.
Brass plate and PC bot plate are also been made for having a look.
201232-0201234-1201236-2
201238-3201240-4201242-5
201244-6201246-7
We are still waiting for a payment provider to activate credit card payment at the moment.
And a new white prototype is in progress while waiting for it to be proved. We hope they both will be ready soon! :thumb:
Offline Shockion
« Reply #106 on: Thu, 02 August 2018, 00:29:20 »
Will there be an assembly option?
Offline Kitley
« Reply #107 on: Thu, 02 August 2018, 00:58:35 »
Looks gorgeous. I've been looking for a new ISO TKL for a little while, so really excited I found this!
I would absolutely be down for a blue, and maybe a white depending how matte it ends up looking. I suppose I'll finally have to learn how to solder as well.  :-[
The page mentions south-facing LEDs -- does this have keycap lighting as well as the underglow, or did I misunderstand?
    • Shop
« Reply #108 on: Thu, 02 August 2018, 02:04:34 »
Cheers!
Yes the board supports both in-switch LEDs and RGB underglow. But as in-swich LEDs are facing south, you'll need to find shinethrough keycaps which alphas are on the bottom side of surface. That way the light will be able to go through.
If you are not looking for that effect, then don't worry about keycap choice. ;)
Offline Darknight00z
« Reply #109 on: Thu, 02 August 2018, 05:05:50 »
The renders look fantastic. I pray Doppio GB and CA66 GB doesn't clash in the same period.
    • Shop
« Reply #110 on: Fri, 03 August 2018, 03:31:16 »
Rough pics shot by factory after CNC. It's been sent to another place for doing eletrophoresis.
Hope it'll be finished soon! :thumb:
201314-0201316-1
Offline DasGnome
« Reply #111 on: Tue, 07 August 2018, 08:48:01 »
@playKeyboardTW did white completely replace the white-silver then? :(
Offline Kallus
« Reply #112 on: Tue, 07 August 2018, 09:00:44 »
Yeah i wanted a silver finish too....  :(
    • Shop
« Reply #113 on: Wed, 08 August 2018, 20:24:46 »
You guys all expected to have silver? I though most people prefer white to silver. :eek:
Offline breckstar
« Reply #114 on: Wed, 08 August 2018, 20:55:47 »
I think a real white, not fake mao white, it's a great option. Whether it is electrophoresis, cerakote, or powder coat doesn't matter too much to me, as long as it is white white white. Not the bamboozle grey that is mao white.
Offline DasGnome
« Reply #115 on: Wed, 08 August 2018, 21:07:42 »
From last month...
I actually really love the the first design with the nameplate. I would love that with WKL :(
Is the Silver like the CA66 white-silver?
Most people need those 3 keys according to feedbacks. So we put them back. :eek:
Yeah, the silver would be similar to CA66's. If you want it whiter you can just pick up a white one. :thumb:
    • Shop
« Reply #116 on: Wed, 08 August 2018, 21:11:42 »
From last month...
Surly we can put Silver back into a option. No problem.
Just thought that most guys want silver to be as white as possible, so why don't we make a white color directly? ;D
    • Shop
« Reply #117 on: Fri, 10 August 2018, 07:56:20 »
Hi guys!
We are taking orders for TW buyers for the first 20 sets at the moment. Think some of you guys might wanting to get one.
If anyone is interested in a WKL(only WKL) version, please let us know by sending a pm.
The official Doppio GB will be hold after CA66 GB is done. :thumb:
    • Shop
« Reply #118 on: Sat, 11 August 2018, 10:24:51 »
Just finished a white color sample with matte finish.
Pics were shot by factory, and mobile phone. Glad to see the result. :p
201833-0201835-1201837-2
201839-3201841-4201843-5
Offline stoic-lemon
Re: [IC] Doppio - 80% Custom Keyboard Kit (white color sample pics updated)
« Reply #119 on: Sat, 11 August 2018, 10:53:45 »
CA66 photobombing :)
Offline SolidCactus
« Reply #120 on: Sat, 11 August 2018, 11:15:10 »
The new matte white looks incredible! I'm ready to rock and roll whenever it's available.
Offline cijanzen
« Reply #121 on: Sat, 11 August 2018, 12:09:03 »
It’s already on their store. They only have 10 spots left so get in fast. They will be running an open gb after CA66 if you can wait.
Offline clik_clak
« Reply #122 on: Sat, 11 August 2018, 12:18:23 »
I can't find it anywhere on the store. The only thing they have is a link to the IC that links back to this thread.
Offline SolidCactus
« Reply #123 on: Sat, 11 August 2018, 12:19:07 »
Yeah tried that. Purchased it and got refunded so not sure what the deal is?
Can you please share the link you can see the 10 spots left on?
Offline coffeeshopcoder
« Reply #124 on: Sat, 11 August 2018, 13:01:02 »
He said they are on taking orders for the first 20 from Taiwan. The full international the will run after ca66. He also mentioned that if any wanted just a WKL version, to pm him.
Sent from my Nexus 6P using Tapatalk
    • Shop
« Reply #125 on: Sat, 11 August 2018, 13:08:13 »
Hi!
The small pre-sale is only for WKL version.
SolidCactus ordered a WK Doppio which is not available right now. So we refunded the order.
We wrote down the note on the invoice, but seeming like it didn't show up for SolidCactus.
Please send me a pm if you want to get an early ticket for a WKL Doppio.
Invoice will be sent via shop for the receiver to pay. :thumb:
« Last Edit: Sat, 11 August 2018, 13:11:38 by PlayKeyboardTW »
    • Shop
« Reply #126 on: Sun, 12 August 2018, 21:32:27 »
Final 5 spots for WKL Doppio. PM me soon if you wanna get one! :-*
Offline cijanzen
« Reply #127 on: Sun, 12 August 2018, 21:34:02 »
If I hadn’t sworn to myself that I’d only buy a TKL if I designed it myself I would buy this! It’s a great looking design.
Offline DasGnome
« Reply #128 on: Tue, 14 August 2018, 11:29:42 »
Do we have an estimated ship date for this early round? :)
    • Shop
« Reply #129 on: Tue, 14 August 2018, 11:39:59 »
Haha give Doppio a chance :p
1 to 1.5 month approximately if everything goes smoothly. :thumb:
Offline cijanzen
« Reply #130 on: Tue, 14 August 2018, 12:19:41 »
I’ll be in for CA66 at least!
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #131 on: Tue, 14 August 2018, 14:24:28 »
Vinegar Doppio, I like it.
Custom name plates are always cool.
Offline LeoZ
« Reply #132 on: Tue, 14 August 2018, 20:23:39 »
Very interested in this kit!
Offline rymnd6c28
« Reply #133 on: Wed, 29 August 2018, 04:47:35 »
How thick is the plate will be? i heard thick plates are what cool kids play with these days. Im 100% in if there's thick steel/polcarb plate, brass maybe too expensive.
Offline Chowboi
« Reply #134 on: Wed, 29 August 2018, 12:42:29 »
Is it possible to add a gold anodized colour? I'm sure other people would like the option.
Offline rymnd6c28
« Reply #135 on: Fri, 28 September 2018, 04:41:58 »
Is this still gonna happen?
Offline eyedrop
Offline p_blaze
« Reply #137 on: Fri, 05 October 2018, 20:32:26 »
any chance for a brighter red case color (like the plate)?
Offline BserLarry
« Reply #138 on: Mon, 22 October 2018, 11:32:55 »
Noob question, looking to pick up custom Keebs and soldering. are stabilizers usually included for custom keebs or must I buy separately?
Offline BserLarry
« Reply #139 on: Mon, 22 October 2018, 11:33:39 »
Looking forward to purchasing a Dope-io when the GB starts
Offline eyedrop
« Reply #140 on: Mon, 22 October 2018, 11:33:55 »
Usually they are not included in the kit.
Sent from my PH-1 using Tapatalk
Offline BserLarry
« Reply #141 on: Mon, 22 October 2018, 11:34:42 »
Aye thanks my man
Offline LoneWolf6
« Reply #142 on: Mon, 29 October 2018, 13:47:27 »
Definitely want the WK version!
Offline darthzero
« Reply #143 on: Thu, 03 January 2019, 04:31:55 »
Any news about the pre-sale boards? Last update is from 3 month ago.
Discord: kuno#0600
Reddit: u/darthzero
Offline DasGnome
« Reply #144 on: Thu, 03 January 2019, 08:44:49 »
Afaik they were all sold, made, and delivered.  I've had one for a while.
Offline darthzero
« Reply #145 on: Thu, 03 January 2019, 11:26:57 »
I ordered one but didn’t receive it so far. I assumed they weren’t ready yet. To be precisely, last update I’ve got was 13. of November.
« Last Edit: Thu, 03 January 2019, 11:30:19 by darthzero »
Discord: kuno#0600
Reddit: u/darthzero
Offline DasGnome
« Reply #146 on: Thu, 03 January 2019, 12:18:08 »
You should definitely bother them about it, just shoot em an email.
Offline darthzero
« Reply #147 on: Thu, 03 January 2019, 14:38:32 »
feelsbadman
How do you like it? Didn’t see any pictures out in the wild (here and reddit) and what colour did you choose?
Discord: kuno#0600
Reddit: u/darthzero
Offline glubazoid
« Reply #148 on: Sat, 26 January 2019, 01:23:29 »
Are the qmk files on the repo?
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #149 on: Tue, 29 January 2019, 13:16:45 »
  • Estimated price?
    Weight total if you can guess?
    Will it sound good and compact or hallow?
    No brass weight option... to keep the price down?
    Where do you guys ship from, possible to declare lower value so people have not to pay 1/3 of the price to customs?
Looks interested might join :)
