Author Topic: [IC] Doppio - 80% Custom Keyboard Kit (white color sample pics updated)  (Read 64206 times)
Offline darthzero
Re: [IC] Doppio - 80% Custom Keyboard Kit (white color sample pics updated)
« Reply #150 on: Wed, 30 January 2019, 10:56:04 »
  • Where do you guys ship from, possible to declare lower value so people have not to pay 1/3 of the price to customs?
Discord: kuno#0600
Reddit: u/darthzero
Offline skaloola
« Reply #151 on: Wed, 30 January 2019, 13:43:42 »
I'll likely buy one.  Love that it's affordable, hope that doesn't mean it sacrifices something for that price though
Offline TheMastermind
« Reply #152 on: Sat, 16 March 2019, 16:23:25 »
Will there be a public GB with the option of having it WKL?
Offline kilobravo898
« Reply #153 on: Sat, 30 March 2019, 01:12:26 »
I'm currently having issues with QMK flashing with the PCB.
Seems that the default flashing had some issues and i'm unable to find a default hex file for the 80% playkeyboardtw pcb online or in qmkconfig.
If anyone has had this problem and solved it, would you mind sharing your solution and maybe a copy of the hex file that worked for you?
Thank you!
« Last Edit: Sat, 30 March 2019, 01:53:39 by kilobravo898 »
Offline BlueBoy
« Reply #154 on: Sun, 20 October 2019, 20:57:12 »
Did this group buy already happen? and also did you remove the badge?
« Last Edit: Mon, 21 October 2019, 13:57:23 by BlueBoy »
