Author Topic: Where's the equals sign? Space Saving Model M  (Read 2504 times)
Offline phototristan
    • https://www.youtube.com/phototristan
« on: Wed, 21 April 2010, 09:31:00 »
On the Space Saving Model M, you can get a number keypad on some letter keys by using shift - numlk. For that mode, I see all the numbers and plus, minus, times and divide but I don't see an equals sign. Where is that?
Do I have to go out of numlk mode to press equals?
EDIT- I'm assuming the Enter key does it?
« Last Edit: Wed, 21 April 2010, 09:34:03 by phototristan »
Offline Rajagra
« Reply #1 on: Wed, 21 April 2010, 10:12:49 »
I don't see an equals sign on any of my standard number pads!
Edit> Ah, I see your point. The normal equals key becomes plus on the Space Saving when you enable the numpad. Could be inconvenient.
« Last Edit: Wed, 21 April 2010, 10:18:54 by Rajagra »
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #2 on: Mon, 03 May 2010, 07:59:41 »
Quote from: phototristan;174082
There is no equals sign as part of the numeric keypad on the IBM PC keyboard. There are the ten digits, the decimal point, Enter, +, -, *, and /, and Num Lock.
So, to type an equals sign, one would have to use the +/= key on the regular keyboard. Some calculator applications might use the Enter key either for an equals sign, as noted, or even as the RPN Enter key.
A different rationale was used for the numeric keypad on the 122-key keyboard, or on IBM terminal keyboards. There, there is a - key, but no other arithmetic operator keys, so it is intended to change the sign of a number to negative rather than as the subtraction operator. There's also a tab key, a space key, and a comma; keys relevant to entering numbers, not calculating with them. There is still an Enter key, and two unused keys, in the positions occupied by Num Lock and / on the numeric keypad on the PC. (* becomes , and - becomes space; the + key is split into two keys, the top one being the Tab key, and the bottom one being -.)
