Author Topic: Want to make a programmable mechanical keyboard  (Read 2763 times)
Offline bak3d
« on: Wed, 04 July 2018, 12:33:23 »
Hey,
I am just getting started to make my very own keyboard, it's just a small project and I want to add 5 cherry mx red switches on my keyboard.
I want every key to be programmable and can be programmed using some kind of s/w. Please help me out in this.
Offline Kilgarah
Re: Want to make a programmable mechanical keyboard
« Reply #1 on: Wed, 04 July 2018, 12:34:07 »
What keyboard do you currently have that you want to add to?
Sent from my SM-G955U1 using Tapatalk
Offline bak3d
« Reply #2 on: Wed, 04 July 2018, 12:35:44 »
Hey, I want to make a keyboard of my own
Offline Kilgarah
« Reply #3 on: Wed, 04 July 2018, 12:40:51 »
Alright, so easiest way will be to handwire 5 keys up to a pro micro. You'll need diodes (1N4148), switches, a pro micro, wire, and some soldering experience. Alternatively, you could design a PCB if that's more up your alley. Here's Matt3o's guide to handwiring. I'd start there.
https://deskthority.net/workshop-f7/brownfox-step-by-step-t6050.html
Offline bak3d
« Reply #4 on: Wed, 04 July 2018, 16:16:13 »
can you suggest some good USB/Bluetooth based controllers? that's the last part to figure out after my research.
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #5 on: Wed, 04 July 2018, 16:23:25 »
Pro micro, from Sparkfun or a knock off from eBay. Something with the ATMEGA32U4 controller would be easiest.
Offline Kilgarah
« Reply #7 on: Wed, 04 July 2018, 16:34:38 »
https://www.aliexpress.com/item/Free-Shipping-New-Pro-Micro-for-arduino-ATmega32U4-5V-16MHz-Module-with-2-row-pin-header/1348800135.html
found one here and it is cheap and new!
Yep, that'll work! It's what's used in most non-SMD builds these days. Good luck!
