Author Topic: [IC] H87a: QMK-powered TKL PCB  (Read 70751 times)
Offline redbanshee
  • actually Dade Murphy
Re: [IC] H87a: QMK-powered TKL PCB
« Reply #50 on: Tue, 24 July 2018, 23:25:53 »
In if its compatible with Mars 8.0. Will have to research this since it's not included in the spreadsheet yet...
It wont fit Mars 8.0 sorry  :(  the proprietary mars pcb has a really long usb "neck", seen here: https://uploads.tapatalk-cdn.com/20180424/cf17c7b45d58f5d0dbfb14c264b167c6.jpg
Ugh that's exactly the issue I thought it might have ;(
Should update the spreadsheet ;)
If you scroll down to the "TKL Cases packaged with Custom PCB's" section you will see Mars 8.0 is included.
The spreadsheet is for a.87 compatible cases mostly, witch Mars 8.0 isnt unfortunately  :(
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #51 on: Tue, 24 July 2018, 23:32:41 »
RFQ for PCB fab + assembly submitted
Finishing up the protos this week, goal is to ship them next Monday July 30
Offline redbanshee
« Reply #52 on: Tue, 24 July 2018, 23:36:49 »
Now that i think about it, technically you may be able to use h.87a with Mars 8.0 but you would have to remove the usb port and then solder the usb wire directly to the pcb... depending on the clearances inside the mars8.0 case it could work.
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #53 on: Wed, 25 July 2018, 00:01:05 »
Could also put in the cable before assembling the bottom case, depends on the cable dimensions tho
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline hineybush
  • student of error
« Reply #54 on: Wed, 25 July 2018, 00:02:27 »
The PCB will have a removable/snap-off USB port, so this is totally doable
Offline hineybush
  • student of error
« Reply #55 on: Wed, 25 July 2018, 09:15:55 »
Pricing in, safe to say we can def hit the $45 mark starting at 50 total orders. There will likely be a drop to $40 per at 200 total, but that's not set in stone yet.
Offline Captain Shwah
« Reply #56 on: Wed, 25 July 2018, 09:45:37 »
That's awesome to hear. I'll definitely pick up a few at that price  :thumb:
Offline SolidCactus
« Reply #57 on: Wed, 25 July 2018, 10:15:13 »
Awesome! I think I would be in for a few at that price point.
Offline Captainbuttmonkey
« Reply #58 on: Wed, 25 July 2018, 18:21:38 »
In, I believe I'm correct in thinking this will be compatible with a Mira?
Offline Pendylan
« Reply #59 on: Fri, 27 July 2018, 16:47:20 »
I'm in.  I'll most likely pick up 2, will try to use it in The Moon.
Offline bciamny
« Reply #60 on: Fri, 27 July 2018, 21:56:59 »
i think i'm in for two as well. :)
Offline Chimera
« Reply #61 on: Fri, 27 July 2018, 23:24:10 »
I'm in for one for my Mira as well, It's B for Mira iirc, can anyone confirm?
Offline ns90
« Reply #62 on: Fri, 27 July 2018, 23:30:04 »
I believe it should fit the Mira. That's why I'm interested
Offline LifeZ
  • LifeZone
« Reply #63 on: Sat, 28 July 2018, 10:15:25 »
I think there is one problem.
It seems that the fixation of the space bar stabilizer is unstable.
200912-0
LZ Limited
Offline hineybush
  • student of error
« Reply #64 on: Sat, 28 July 2018, 14:42:41 »
Thanks, that will be fixed on the production version.
« Last Edit: Sat, 28 July 2018, 16:04:41 by hineybush »
Offline bciamny
« Reply #65 on: Sat, 28 July 2018, 19:24:56 »
that solution is quite similar to the l3 tkl boards. it seems that south facing spacebars may require it for stability.
Offline hineybush
  • student of error
« Reply #66 on: Sat, 28 July 2018, 20:03:14 »
Yeah the Mech27 one is the same way. Keep in mind I'll be doing an h87b version in the future too, with the spacebar stab oriented the other way.
« Reply #67 on: Sun, 29 July 2018, 00:34:49 »
well, you can't screw in the stab all the way if you don't have that, so yes
Offline hineybush
  • student of error
« Reply #68 on: Thu, 02 August 2018, 10:35:27 »
Yeah dw the production version has the full stab coverage lol
Prototype h87a assembled in an acrylic unicorn:
Thanks to invisibiliti
Offline dyka.tran
« Reply #69 on: Thu, 02 August 2018, 10:46:49 »
Really awesome. I'm waiting for your GB, one thing I'm kinda afraid is that shipping fee from your country to mine will make the price go up too much  :(
Offline hineybush
  • student of error
« Reply #70 on: Thu, 02 August 2018, 10:52:29 »
Where are you at in the world?
Right now international from me will be about $23 I think, based on a 1lb box. I plan to have at least a European proxy, and I'm looking into an Asian one.
Offline dyka.tran
« Reply #71 on: Thu, 02 August 2018, 11:15:09 »
Vietnam to be precise.
Offline hineybush
  • student of error
« Reply #72 on: Thu, 02 August 2018, 11:19:11 »
Cool. My friend in Indonesia is interested in doing proxying for SEA, so it's very possible.
Offline dyka.tran
« Reply #73 on: Thu, 02 August 2018, 12:07:19 »
Cool x2, then maybe I will get x2 PCBs  ;)  So when will you launch GB?
Offline hineybush
  • student of error
« Reply #74 on: Thu, 02 August 2018, 12:36:03 »
Aiming for 2-3 weeks. I have to change the diode footprints a little bit, and switch to a different package (SOD-323 is too difficult to repair/reflow if necessary, imo) so a little bit of tweaking there has to be done. Once that's finished, I have to order some assembled prototypes to verify the factory's processes and then we'll be good to go.
Offline odd
« Reply #75 on: Thu, 02 August 2018, 13:02:16 »
I would def be down for a couple of these
Offline ozan6661
« Reply #76 on: Thu, 02 August 2018, 13:17:13 »
im ready to be proxy for people south east asia & asia don't worry  ;D ;D
Offline iNViSiBiLiTi
« Reply #77 on: Thu, 02 August 2018, 23:13:32 »
prototype pcb received.
went in my Acrylic Unicorn as commissioned  ;D
60%: Prophet, GSKT-00 x2, Poly GSKT-00-Z, Weaven, Sangeo60, Unikorn R2.1, Ciel60, DNworks DM
TKL: TGR Jane V2, Jane V2 CE, KFE, Noxary 280 S, Acrylic Unicorn, Igris V1, LZ-GHv2, Bias R2, HMKB
Misc: Bulgogi Board (VA104M), Belle En Rose, Treeleaf 917, TGR 910 ME, ai03 Vega
Offline hineybush
  • student of error
« Reply #78 on: Tue, 07 August 2018, 03:05:58 »
product page is up, buy TBD: http://shop.hineybush.com/product/h87a
Currently waiting for funds to order a run of 10 assembled prototypes of the final version. Once those are verified good to go, the buy will start.
Timeline for start is about 2 weeks from now
« Last Edit: Tue, 07 August 2018, 09:20:50 by hineybush »
Offline wholypantalones
  • text and icon mods plz.
« Reply #79 on: Tue, 07 August 2018, 06:38:44 »
Nice, will be in for a couple or more of these.
Offline dyka.tran
« Reply #80 on: Tue, 07 August 2018, 08:29:12 »
Awesome man, please remember to establish an Asian proxy  ;D
Offline ProtonDecay
« Reply #81 on: Tue, 07 August 2018, 09:47:36 »
I'm re-reading the thread with respect to case compatibility, and am wondering: why can't there be multiple USB pads and sets of mounting holes, the same way as there are multiple overlapped pads for switches?
Offline hineybush
  • student of error
« Reply #82 on: Tue, 07 August 2018, 10:24:29 »
Mount holes aren't super important, as barely any cases this would even fit use them. I've based the current ones off of the b.87.
Multiple USB ports could definitely work, I might have to do that for the future. There are already pads to solder to as well, so a daughterboard can be easily used. I have to double check the pin spacing on the footprint and update the product description with that, iirc it's set up to use a variant of JST
Offline ProtonDecay
« Reply #83 on: Tue, 07 August 2018, 11:22:10 »
Aaahh, footprints is the term I meant to use. Designing with footprints at all of the most common USB port locations and shipping with a loose port or two.
« Last Edit: Tue, 07 August 2018, 12:45:40 by ProtonDecay »
Offline hineybush
  • student of error
« Reply #84 on: Tue, 07 August 2018, 12:49:01 »
Might work, perhaps in the future
Offline hineybush
  • student of error
« Reply #85 on: Mon, 13 August 2018, 23:18:51 »
production samples ordered
PCB confirmed to fit TX84, Mira and Keycult No.1
« Last Edit: Tue, 14 August 2018, 08:27:03 by hineybush »
Offline bciamny
« Reply #86 on: Tue, 14 August 2018, 01:17:33 »
nice. my mira is sitting out atm because of a faulty pcb. this can't come soon enough :)
Offline gt1989
« Reply #87 on: Tue, 14 August 2018, 13:14:57 »
Great news about the no. 1, planning on getting 2 pcbs.
Offline hineybush
  • student of error
« Reply #88 on: Wed, 15 August 2018, 13:01:39 »
ETA for the prototypes to get to me is ~3 weeks
Offline dyka.tran
« Reply #89 on: Thu, 16 August 2018, 04:51:30 »
A (kinda) noob question: How thick is the mini-USB port?
Offline hineybush
  • student of error
« Reply #90 on: Thu, 16 August 2018, 16:41:41 »
in which direction?
Offline dyka.tran
« Reply #91 on: Thu, 16 August 2018, 22:16:25 »
in which direction?
I'm planning for a aluminum plate, but the maximum thickness of its is only 1.5mm, so may I have to make a gap on top housing to fit the usb port?
Offline hineybush
  • student of error
« Reply #92 on: Thu, 16 August 2018, 22:34:52 »
in which direction?
Ahh yeah. That's a common thing on plates for A.87 PCBs.
Offline hineybush
  • student of error
« Reply #93 on: Mon, 27 August 2018, 02:57:14 »
Should have the production samples in the next 7-10 days. Will verify and open the GB then if they're good :D
Offline dyka.tran
« Reply #94 on: Mon, 27 August 2018, 03:07:28 »
Are you still planning to establish an Asian proxy?
Offline hineybush
  • student of error
« Reply #95 on: Mon, 27 August 2018, 03:08:21 »
Yes, a friend in indonesia will be proxying
Offline dyka.tran
« Reply #96 on: Mon, 27 August 2018, 03:28:56 »
Aww yiss! I still have to find a decent case for it though  :(
Offline Artemie
  • Don't Let Your Memes Be Dreams
« Reply #97 on: Tue, 28 August 2018, 09:39:46 »
Can't wait.
| 420CL | Fanoe | Porpoise | KFE R1 Silver| MxSS |  is0 Pink & Silver | HBCP Polycarbonate | Matrix 2.0 Additional Purple | TGR Police | Singa Jaguar Green | KFE R2 Blue | RS so lit | Dolch CR Black | Jelly 60 Blue | Belle en Rose | Kei R2 Olive | Dalco 959 Mini | Aripeko
Boards in GB: | IU board |
Previous Boards: QXP | Singa  | UTD | Taichi | Jane v2 Red | Jane v2 CE
Offline hineybush
  • student of error
« Reply #98 on: Tue, 04 September 2018, 15:30:28 »
pic from the manufacturer. the 10 protos are being sent to me today/tomorrow.
« Reply #99 on: Tue, 04 September 2018, 19:05:50 »
What are we thinking on turn around on these in a gb? I definitely need a few of these.
