Author Topic: [IC] H87a: QMK-powered TKL PCB  (Read 70750 times)
Offline pr0ximity
Re: [IC] H87a: QMK-powered TKL PCB
« Reply #150 on: Thu, 13 December 2018, 20:30:44 »
wew flex version, gonna need another partial plate
Offline gabbbe
« Reply #151 on: Sun, 03 February 2019, 13:23:52 »
I'm very excited for the alps version!
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #152 on: Sun, 03 February 2019, 14:22:55 »
I plan to launch a group buy for the alps-only version and a 1.2mm thick version (more flex) the week after Christmas. MOQ will be ~50 for each. Price will likely be $50 USD
Is the 1.2mm PCB the one with the relief cuts?
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #153 on: Sun, 03 February 2019, 14:23:38 »
oh yea this was delayed til a few weeks from now, after CNY
no flex cuts
Offline Zambumon
    • Keyset projects
« Reply #154 on: Sun, 03 February 2019, 14:25:29 »
no flex cuts
nice
Do people need to add washers to the hook side of the stabs to compensate for those extra 0.4mm?
Offline hineybush
  • student of error
« Reply #155 on: Sun, 03 February 2019, 14:28:03 »
no flex cuts
nice
Working on something special for that
Offline Zambumon
    • Keyset projects
« Reply #156 on: Sun, 03 February 2019, 14:46:32 »
no flex cuts
nice
nice
Offline hineybush
  • student of error
« Reply #157 on: Tue, 08 October 2019, 13:35:22 »
hi, bringing this back up
working on a catalog of the PCBs i have, and h87a is included obviously https://docs.google.com/document/d/10nLrZIm_f931-tRibbKhoCvMC9WgixuB58XC4Huam7k/edit?usp=sharing
also consider this the update for interest in the new h87a version which I will be buying outright and opening for pre-orders once I verify the prototype (should happen in the next week or two)
big changes here:
JST SH connector support for the USB lines as well as an RGB header - I'm considering adding an option to this for me to solder a connector on before shipping (would be like +$3)
RGB header has a passthrough for a front-facing RGB strip/bar (working on developing a bar atm) for boards with stuff between the arrows and nav keys
A small bypass for said RGB header, so you can do either normal underglow or the front strip (both is also possibly in the works, need to review that)
More robust removable spacebar mounts on the bottom
Removed the dedicated reset pins to short, now added into the ISP header (since the signals exist there anyway lol)
South facing right shift stab mounting only
Better labling for the jumpers for Caps/Scroll LED vs. having that LED part of the regular in-switch LEDs
I am considering removing the universal north/south spacebar mounts, I think north-facing only would be better (plates are easy to modify) but i'd love to hear feedback on this
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #158 on: Tue, 08 October 2019, 13:55:13 »
i love hineybus
Offline redbanshee
  • actually Dade Murphy
« Reply #159 on: Tue, 08 October 2019, 14:31:30 »
This is one of the main features! Tons of boards are south only, Duck, LZ, OTD, etc etc the list goes on and on! South stabs are MUCH less rattly! If your going for compatibility, it would be pretty counter-productive to do north only.
Whats the reasoning with going north only?
Offline hineybush
  • student of error
« Reply #160 on: Tue, 08 October 2019, 14:32:13 »
hmm idk, i just sort of prefer it. I can certainly leave it in, wouldn't be a bad thing
Offline IOVERCALLHISTIOCYTES
« Reply #161 on: Tue, 08 October 2019, 17:17:27 »
As someone relatively new to customs, a lotta established boards will take this pcb and those of us who bought second (or third, fourth hand) only have one desoldered pcb with which to work may not have other backups. Having compatibility might be nice. Especially for Elli’s Love TKL where a few of us bought with the idea we’d get a PCB from your next run.
I defer to experts about build quality and PCB design.
Offline im_hide
  • dont think
« Reply #162 on: Fri, 11 October 2019, 02:46:08 »
I too agree that having the option of north/south stabs is the right way to go. My first impression of the h87a was that it was the "go-to" TKL pcb. The one that does it everything you need it to without compromising. I think removing features just based on personal preference kinda kills a lot of what draws me to this PCB.
Offline mech0nly
« Reply #163 on: Fri, 11 October 2019, 08:43:49 »
Yes please. Need a thinboi for my halfplate LZ-CLS build.
In addition, I'd be extremely happy if the PCB using CEM3 material instead of FR4 for extra elasticity (yep I already checked material tables), just like OTD PCBs ;)
Thank you very much hiney!
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
Offline hineybush
  • student of error
« Reply #164 on: Fri, 11 October 2019, 08:49:19 »
I'll look into that, I've been meaning to!
Offline Yeoh
« Reply #165 on: Fri, 11 October 2019, 08:58:18 »
the option for north/south facing spacebar stab is a big draw to the pcb imo
Offline Fnzzy
« Reply #166 on: Fri, 11 October 2019, 10:00:03 »
Big supporter of south facing spacebar stab here. Having north facing as an additional option is just a bonus.
Would be very hesitant to buy a north facing only PCB to be honest.
Offline alkaiser
  • hello.
« Reply #167 on: Fri, 11 October 2019, 10:10:00 »
South facing please!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #168 on: Fri, 11 October 2019, 12:07:19 »
+1 for south facing because swapping wires is so much easier if there's an issue.
Though I know compatibility is a thing.
Offline wholypantalones
  • text and icon mods plz.
« Reply #169 on: Fri, 11 October 2019, 12:34:32 »
+1 for leaving it north / south spacebar. One of the many draws of this pcb is the options.
Offline GraffitiDecos
« Reply #170 on: Thu, 31 October 2019, 09:49:52 »
Can someone enlighten me as to what the difference is for between north and south fitment? Is it a case thing? plate thing? Forgive my ignorance on the subject.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #171 on: Mon, 11 November 2019, 07:56:04 »
It's a plate and PCB thing. One can orient the spacebar stabilizer wire to face in either up (north) or down (south) direction. Boards have one or the other.
Offline jedidood
  • aka neovisual
« Reply #172 on: Tue, 07 January 2020, 01:08:59 »
Has this became the past? I missed it?
Offline hineybush
  • student of error
« Reply #173 on: Tue, 07 January 2020, 01:09:58 »
Shipping the rest of the pre orders through the week. the rest will be up afterwards. check here or join my discord (discord.hiney.cc) for updates :)
Offline jedidood
  • aka neovisual
« Reply #174 on: Tue, 07 January 2020, 02:45:52 »
