Author Topic: [IC] GMK Monochrome - GB September 1st  (Read 124338 times)
Offline duckboi
Re: [IC] GMK Monochrome
« Reply #50 on: Mon, 16 July 2018, 05:58:24 »
Oh I am in this for sure. Any further update regarding the set?
At the moment, we are kinda just in a waiting period while finalizing things. Hold tight, it’s gonna happen!
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #51 on: Mon, 16 July 2018, 08:38:27 »
I really hope the novelties go through. Worst case scenario, are you considering on a new set of novelties to go with this set in case Disney does not approve the project?
Offline duckboi
« Reply #52 on: Mon, 16 July 2018, 10:23:22 »
It is pretty unlikely that we will be doing novelties for this, sorry. We are just going to omit the novelties and continue on with the rest of the set.
Offline chuckdee
« Reply #53 on: Mon, 16 July 2018, 10:39:30 »
I think WOB and BOW aren't generally supported for novelites anyway.
Offline compjunkie8888
« Reply #54 on: Mon, 16 July 2018, 23:51:38 »
I might be over looking it but I am not seeing a 1.25u Caps lock. Otherwise the set looks fantastic.
Offline duckboi
« Reply #55 on: Tue, 17 July 2018, 14:23:46 »
Correct, there is no plan for a 1.25u Caps Lock key.
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #56 on: Tue, 17 July 2018, 15:22:09 »
Monochrome Update
Updated kits
Core Kit
Here is what change:
  • we added a 2u R4 shift key;
  • we added a 1u R4 FN key;
  • we changed the R4 shift to icon only; and
  • we changed the icon on the capslock key to the one used in GMK 9009 R2.
Extra Kit
Extras
I am an artisan lovers, and we decided we would keep the artisans.
  • Alphakeycaps is on board and there will be a raffle for his Jedi Blinker. We will produce around 10 of those and they will be raffled between GB participants; and
  • RAMA offered to produce this beauty. This is a black anodised X or O keycap with laser edged white stars (subtle but stunning). Those will go for the usual price for RAMA keycaps, so $36 for US/Asia and 42€ for EU (big thanks to RAMA for keeping the price low for us <3 I owe you one!) and have a MOQ of 50. Everyone can buy them and everyone can buy as many as they want.
Vendors
  • MyKeyboard.eu has been confirmed for Europe, ;
  • We are still in discussion with vendors for the States and Canada; and
  • zFrontier would be our vendor for Asia, Africa, Australia and New Zealand, though we are still waiting for a confirmation.
Thanks for reading guys!
« Last Edit: Tue, 17 July 2018, 16:09:59 by JSaintS »
Offline fleeceman
« Reply #57 on: Wed, 18 July 2018, 05:47:24 »
ISO UK support no longer in the base kit? I'm out
Offline SolidCactus
« Reply #58 on: Wed, 18 July 2018, 06:14:50 »
Nice new renders! Any ideas on when it might kick off?
Offline JSaintS
    • JSaintS
« Reply #59 on: Wed, 18 July 2018, 06:17:29 »
It never was in the base kit of our keyset
Offline Altain
  • Formerly zungzangbi
« Reply #60 on: Wed, 18 July 2018, 06:39:16 »
Damn, this looks beyond good! I'm in when this goes GB.  :thumb:
Offline Kerasan
« Reply #61 on: Wed, 18 July 2018, 12:14:59 »
I hope so much that reaches the moq, this set is already perfect so, shame about the novelties but it was predictable.
KMK Labs
« Last Edit: Wed, 18 July 2018, 12:17:06 by Kerasan »
Offline kema
  • Designer
    • kevinmadesign
« Reply #62 on: Wed, 18 July 2018, 14:40:10 »
The speckled rama caps look so good
Offline MikeTheTiger
« Reply #63 on: Sun, 22 July 2018, 13:18:54 »
I’m loving this. What are your thoughts on adding 40s support for Planck, Minivan, Pearl, etc?
"all the numbers or none of them cmon man" -Kokaloo
Offline konstantin
  • Formerly constexpr
« Reply #64 on: Mon, 23 July 2018, 07:32:30 »
Suggestions:
  • Add R3 PgUp, R4 PgDn to either the core or extra kit (preferably the former).
  • Replace Code with System / Sys.
Reasoning for R3 PgUp, R4 PgDn:
Some 65% layouts use it, e.g. the default WhiteFox, Tada68 and Uniqey C70 layouts. It's included in a couple of core kits (GMK/EPBT Slate comes to mind).
Reasoning for System:
What does Code even mean? It's like the people who put together the first GMK set with Code for the winkey thought: “We didn't know what to put here, so we put Code cause some people here are coders lul.”
Super makes a bit more sense, has a historical background, but nowadays isn't really prominent outside of *nix systems.
System makes the most sense, is neutral (just like Monochrome), and best describes what the key is actually used for: system-specific commands.
In the back of my head I think that GMK already have a System mold, but if it turns out they don't, it's time they made one imo.
« Last Edit: Mon, 23 July 2018, 07:40:46 by constexpr »
Offline chuckdee
« Reply #65 on: Mon, 23 July 2018, 08:12:24 »
Suggestions:
IMO, Code is actually more generic, and can be used for more than just a WIN replacement.  As to what it means?  A shortened abbreviation for KeyCode was my first thought, which makes it make even more sense when used as replacement for other keys that might not be related to system functions.
Therefore, my vote is to keep it.
Offline konstantin
« Reply #66 on: Mon, 23 July 2018, 09:13:56 »
Sure, I'll give you that, but I'd like to say that its primary intended use is to be a winkey replacement. All Code caps are R4, so you're a bit limited as to what other keys you can replace with it (at least on the most commonly used layouts). Since the most common non-standard keys on R4 are usually for layer stuff, I'd say you could use Fn for that purpose equally well, if not better. Other commonly used R4 keys are End and PgDn, and those are both covered (or will be covered) by the set.
« Last Edit: Mon, 23 July 2018, 09:15:56 by constexpr »
Offline chuckdee
« Reply #67 on: Mon, 23 July 2018, 09:17:46 »
Notice, both Fn keys are already in use.  As I said- I personally prefer code. :)
Offline mkarlsson
« Reply #68 on: Mon, 23 July 2018, 12:10:14 »
Afaik code key was used on electric typewriters, TA used to have it. And seems that was intended as an “fn” key. Here is a small paragraph from a sharp typewriter:
Code: [Select]
Find the "Code" button on the keyboard. This button controls various functions of your typewriter and the more familiar you get with using the code button, the easier it will be to work on your typewriter. For example in the Sharp PA 4000 model, pressing the "Code" button plus the “Q” key sets the calculator or cancels it. Pressing the "Code" button plus the “9” key will make the type bold.
Offline konstantin
« Reply #69 on: Mon, 23 July 2018, 14:26:00 »
You have to admit that's a very unorthodox layout you have there (though I like it!). But System could have worked equally as well in those spots, and you probably ended up using those keys for LGUI and RGUI anyway :D
« Last Edit: Mon, 23 July 2018, 14:44:37 by constexpr »
Offline konstantin
« Reply #70 on: Mon, 23 July 2018, 14:37:36 »
Yep, looks like you're right — CODE (capitalized) was apparently first featured on GMK Royal Alpha. It does fit in that set because the original typewriter had it (though it was more like an Fn key as you said). I think System makes more sense in a modern context, where Fn (keyboard metacommands that never make it to the computer) and system commands are more distinct.
Offline chuckdee
« Reply #71 on: Mon, 23 July 2018, 14:43:22 »
Never said it wasn't... which was the reason that I said my preference.  As yours is for system. :)
Offline konstantin
« Reply #72 on: Mon, 23 July 2018, 14:46:23 »
Of course. I guess at the end of the day it just matters what the 3 authors like best :D
Offline mkarlsson
[IC] GMK Monochrome
« Reply #73 on: Mon, 23 July 2018, 15:12:30 »
Given the facts probably the most accurate use would be system as winkey replacement and CODE instead of fn. So we can have both of them
Offline konstantin
« Reply #74 on: Mon, 23 July 2018, 16:34:20 »
But CODE only applies to Triumph Adler and Royal Alpha, not in general. But thanks for siding with me on System :D
Offline mkarlsson
[IC] GMK Monochrome
« Reply #75 on: Mon, 23 July 2018, 16:40:56 »
I don’t think CODE is exclusive from TA, maybe they were the first ones? The paragraph I posted earlier is from Sharp, I believe there are others that have used it too.
And yeah I am with you with system
Edit: found that Canon and Brother also used the CODE key, probably among many others.
« Last Edit: Mon, 23 July 2018, 16:47:38 by mkarlsson »
Offline earlilano
« Reply #76 on: Tue, 24 July 2018, 21:22:35 »
Will the core kit be enough for the Kira keyboard by Input Club? I can't wait to purchase these.
Offline nerium
« Reply #77 on: Wed, 25 July 2018, 08:56:58 »
I'm 100% in for this! I've been scouring the internet for GMK BoW and/or WoB for when my M60A comes and this is exactly what I was looking for. Pumped!
RAMA M60-A Mist w/ BOX Royals | RAMA M65-A Mist (unbuilt) | HHKB Pro 2 | HHKB Pro 2 Type-S | CM Novatouch | Poker II w/ MX Clears | Pok3r w/ MX Blues | SA Godspeed | SA Industrial | SA Ice Caps | SA Modern Selectric | DSA Dolch | GMK 3Run | Hidden Labs Thermochromic | Hot Keys Project Neon Green + Neon Orange
Offline duckboi
« Reply #78 on: Wed, 25 July 2018, 09:26:17 »
Yes, it will cover the Kira. Thanks for the support!!  :D
Offline SolidCactus
« Reply #79 on: Wed, 25 July 2018, 10:22:57 »
This looks like such a great set. I can't wait to pick this one up.
Offline JSaintS
    • JSaintS
« Reply #80 on: Sat, 28 July 2018, 16:30:01 »
Seems like forever since I've update the OP.
We updated the Core and the compatibility kit, here they are:
Also, for those that did not see it, the list of vendors is final:
  • EU: MyKeyboard.eu
  • States: Kono.store
  • Asia/rest of the world: zFrontier
Time to put money aside folks, this is happening for sure :)
Offline SolidCactus
« Reply #81 on: Sat, 28 July 2018, 16:46:52 »
Awesome update! I'm ready to snap this one up.
Any ideas on when the GB might start?
Offline JSaintS
    • JSaintS
« Reply #82 on: Sat, 28 July 2018, 16:49:05 »
We don't have an official date yet but we are aiming at the end of Q3 :)
Offline otanishock
  • ファーストラブ
« Reply #83 on: Sat, 28 July 2018, 22:58:56 »
Can't wait. The hype is real. Any word on those novelties? Still wish to see they could come to life!
« Reply #84 on: Sun, 29 July 2018, 00:38:25 »
windowed caps YES
Offline darthzero
« Reply #85 on: Sun, 29 July 2018, 01:45:40 »
  • EU: MyKeyboard.eu
Any idea what the compatibility kit will cost? 40$+?
Discord: kuno#0600
Reddit: u/darthzero
Offline Marutks
« Reply #86 on: Sun, 29 July 2018, 06:42:11 »
I am interested.  I think this kit would look great on black RAMA M60   :D
Offline Snappo
  • meme
« Reply #87 on: Sun, 29 July 2018, 07:00:04 »
windowed caps YES
 :p
  • EU: MyKeyboard.eu
Yeah around there.
Something like this?
« Last Edit: Sun, 29 July 2018, 07:02:51 by Snappo »
Offline JSaintS
    • JSaintS
« Reply #88 on: Mon, 30 July 2018, 14:56:57 »
Heya everyone!
We trimmed the core kit a little bit to bring the cost down a little more. Here is the final design of the core kit:
With that finalized, we also have the prices for all three vendors:
VendorsBase kit (MOQ 150)Compatibility kit (MOQ 150)RAMA X/O RAMA Laser-etched X/O
MyKeyboard (EU)
132€
37€
42€
44€
KONO (USA)
$140
$40
$36
$38
zFrontier (Asia)1
$1402|$1552
$40|$45
$36
$38
1 Please note that all their prices include shipping whilst that is not the case for other vendors.
2 Prices on the left are for China, prices on the right are for the other countries (price difference explained by the difference in shipping costs)
Also, there will be different price drops depending on the MOQ we hit, so talk about the set to your mom, your cat, your neighbors, the pope!
Offline Altain
« Reply #89 on: Mon, 30 July 2018, 17:17:43 »
HYPED
Offline chuckdee
« Reply #90 on: Mon, 30 July 2018, 19:59:36 »
Just to make sure- those kits are final, correct?  Just making sure as you'd said something about a spacebar kit- not having the space bars in the extras, which includes a lot of other keys.
Offline duckboi
« Reply #91 on: Mon, 30 July 2018, 21:27:34 »
Yes they're final.
Offline Marutks
« Reply #92 on: Thu, 09 August 2018, 15:53:19 »
No 1.5u Code keys?  and only one 1u ctrl / alt ?   It makes this kit incompatible with HHKB layout,  RAMA M60, for example.
Offline tomu
  • hi
« Reply #93 on: Thu, 09 August 2018, 18:50:23 »
nice
G80-3700 | HHKB Pro 2
Offline otanishock
  • ファーストラブ
« Reply #94 on: Thu, 09 August 2018, 19:34:19 »
Million dollars question. When is the drop? My body is ready
Sent from my SM-G955U using Tapatalk
Offline tomu
  • hi
« Reply #95 on: Thu, 09 August 2018, 19:41:27 »
They're aiming for end of Q3
Sent from my LG-H871 using Tapatalk
Offline Water lee
« Reply #96 on: Thu, 09 August 2018, 21:54:57 »
really nice with elephant . :thumb:
make it better!
Offline Kerasan
« Reply #97 on: Fri, 10 August 2018, 07:15:27 »
GMK Metaverse is better
points of view ... I do not like weeb legend so I think the opposite. Also they are two different sets.
KMK Labs.
Offline duckboi
« Reply #98 on: Fri, 10 August 2018, 09:17:19 »
It's not incompatible. There are still R4 1.5u alt and control keys that you are free to use as well as 1u Code keys. The point of this kit is to have compatible keys for as many layouts as possible, not to have perfect legends for every single layout. Thank you for the concern though!  :)
Offline HOBI3CAT
  • FraktalKaps.com
    • Fraktal Kaps Website
« Reply #99 on: Wed, 15 August 2018, 14:53:34 »
Something about the simplicity of the white/black is so nice! Really excited for this set :)
Eat, Sleep, Resin, Repeat.
