Author Topic: Cooler Master MasterKeys Pro L USB version?  (Read 2097 times)
Offline parsa_strife
« on: Sun, 08 July 2018, 09:39:34 »
Hey guys I was trying to figure out if my MK Pro L was set to 1KHz polling rate. According to this wiki and the fact that I couldn't find any information about "USB 1.1 Full Speed (1KHz)", I figured it's only possible through USB 2.0.
And I figured how to see if it's running at Full Speed (1KHz) or Low Speed (125Hz) through EK Switch Hitter. Apparently it runs at Full Speed ONLY on one of the USB ports on my Asus Prime X370-Pro (all ports are USB 3.0 and 3.1)?? Which seems weird to me and I'm not sure how I could change that.
But the weirder thing is that after trying all the ports and using USB Device Viewer from Microsoft Debug Tool it says the keyboard is connected via USB 1.1?
I mean it's fine with me as long as it works at 1KHz with USB 1.1 but you would think it has USB 2.0 port since they mention "USB 2.0 Cable Connector" in the spec page lol.
