Author Topic: XD87 in Stock  (Read 25007 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
XD87 in Stock
« on: Wed, 11 July 2018, 00:46:53 »
XD87 comes into the market.
The new member of XD family supports Cherry MX and ALPS switches, is programmable with TKG and KLE.
The layouts it supports are
Here is the PCB's profile photo
Closer photo
ORDER LINK#
Offline leece3
Re: XD87 in Stock
« Reply #1 on: Mon, 22 October 2018, 15:22:37 »
Can this be flashed with QMK? Thanks.
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: XD87 in Stock
« Reply #2 on: Sun, 11 November 2018, 00:53:32 »
It should be.
I asked the user and was told it would be better to use TKG.
Offline Jacob4341
Re: XD87 in Stock
« Reply #3 on: Tue, 31 March 2020, 20:19:02 »
Hi, I'm looking at ordering one of these when you start shipping out again. If I want to do an alps build, what plate can I use? Can I use the phantom TKL one from mechanicalkeyboards.com? Do you have an alps plate file you could share so I can get one cut?
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: XD87 in Stock
« Reply #4 on: Fri, 03 April 2020, 02:27:40 »
Hello, sorry for the late reply.
I am sorry for now, we don't have ALPS plate for XD87 right now.
I have no idea as well if the phantom TKL works for XD87.
because we don't have such plate for test.
