Author Topic: 130 switch tester + 81 switch tester  (Read 19017 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Thu, 12 July 2018, 02:41:46 »
130 Switch tester
Spec
Total 130 switches(pls check switches type as the following pics)
With Acrylic Base
With Blank Keycaps
These switches are detachable and interchangeable from the acrylic base.
Some switches may be disassembly parts, such as cherry old brown and old blue.....
ORDER LINK
81 Switch tester
Spec
Total 81 switches(pls check switches type as the following pics)
With Acrylic Base
With Blank Keycaps
The switches are detachable and interchangeable from the acrylic base.
order link
