Author Topic: HyperFuse "Code" Keycap  (Read 3886 times)
Offline starhacker
« on: Fri, 13 July 2018, 00:48:50 »
I just received a HyperFuse Origins keyset and its amazing.
I was curious about the origin of the "Code" key cap and why its part of the HyperFuse keyset design. Coming from a software dev, I love the keycap, nice little detail.
Offline Bambino
  • Suited Up Keycaps
Re: HyperFuse "Code" Keycap
« Reply #1 on: Fri, 13 July 2018, 01:10:21 »
Code is a default mold you can use when ordering a set from GMK, much like Ctrl or Alt. I don't think there's any story behind it other than the set designer not wanting to use a Win or windows logo key instead.
Offline starhacker
« Reply #2 on: Fri, 13 July 2018, 02:09:16 »
Didn't know it was a default mold. I thought the designers might have had software related interests/background. Thanks for info!
Offline floristfran
  • I Wanted a foam bath and i got a slimy eel bath
« Reply #3 on: Fri, 13 July 2018, 04:48:39 »
honestly thank god they dont use a the godawful windows 8/10 logo. kills a keyset imo
Offline rich1051414
« Reply #4 on: Tue, 17 July 2018, 09:21:23 »
I like how the code key is usually in a different font color if the keyboard is a three color theme. I use it as my windows key :)
Offline nguyenhimself
« Reply #5 on: Wed, 18 July 2018, 01:11:07 »
It's partly software-dev related. As more people get into this hobby, macOS or Linux folks find it annoying to see a WIN key on their keyboards, so custom keysets start using either SUPER or CODE instead.
