Author Topic: Anyone interested in a full board of these #Blancks?  (Read 3875 times)
Offline NZcaps
« on: Sat, 14 July 2018, 21:04:07 »
We have been working on milled Aluminum caps for a while now. While testing our stems we ended up with these blanks. Thought the would look good as a full set with tight tolerances. They are pretty beefy at the moment so might bring them down to about 12mm.
Just wondering what you guys think.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: Anyone interested in a full board of these #Blancks?
« Reply #1 on: Sat, 14 July 2018, 21:09:17 »
Probably not. They look terribly uncomfortable to type on.
Offline NZcaps
« Reply #2 on: Sat, 14 July 2018, 21:14:16 »
Cheers. Was going for more form over function with these.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #3 on: Sat, 14 July 2018, 21:23:05 »
It would certainly look interesting. Especially in a Planck. Do you have enough of them to at least civet a decent portion? For keyboard science?
Just can't see myself using them =/
Sent from my SM-G950U using Tapatalk
Offline Hokabuki
« Reply #4 on: Sat, 14 July 2018, 22:17:13 »
I would love to have them on a board as a display piece. I would assume the cost would  keep me from actually buying a whole set unfortunately.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #5 on: Sat, 14 July 2018, 23:13:34 »
Is there any way to make the alphas concave with the way you're cutting them?
Offline NZcaps
« Reply #6 on: Sat, 14 July 2018, 23:35:16 »
We are working on some textured full sets that will be a traditional DSA/OEM profile. These were a happy accident that would be a bit cheaper for full sets because only one side needs to be machined on one side.
  • ʘ_ಠ
« Reply #7 on: Sat, 14 July 2018, 23:49:46 »
I would kind of like to try them, if you're seeking testers. I have experience with several different profiles, and type around 100 wpm.
How much would a full set of blanks for an 87 key "TKL" keyboard cost?
Offline x86ect
« Reply #8 on: Tue, 17 July 2018, 17:01:58 »
What's the weight difference between these and, say, a dsa keycap?
