Author Topic: GMK HyperFuse Origins Cap Stems Split  (Read 5540 times)
Offline starhacker
« on: Mon, 16 July 2018, 11:29:19 »
After a week of use some of keycaps stems split in half. For now, I think only two caps are split from the top number row. Had to use super glue on the stems to keep them from breaking off completely. I expected a bit higher quality build for these caps. The stem borders are quite thin.
Any one else had breakage issues with GMK caps? Is there a way to get replacements?
200144-0
200146-1
« Last Edit: Mon, 16 July 2018, 14:13:00 by starhacker »
Offline xondat
  • i'm not a star
Re: GMK HyperFuse Origins Cap Stems Split
« Reply #1 on: Mon, 16 July 2018, 11:31:13 »
Quite unusual to hear honestly.
What switches are you using?
You could contact Originative and see if they have replacements.
Offline starhacker
« Reply #2 on: Mon, 16 July 2018, 11:35:19 »
I am using Gateron Red switches. Are there MX clones that have issues fitting keycaps?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #3 on: Mon, 16 July 2018, 12:30:44 »
Do you have any pics? I've never had issues with GMK splitting like that.
Did you use a keypuller?
Offline titanium
« Reply #4 on: Mon, 16 July 2018, 13:51:52 »
Wow that is not something that you hear everyday... OP go buy yourself a lotto ticket, you are the chosen one!
I'm sure if you contact sheraton @ originativeco.com that he'll be able to help you out, he's a swell fella :)
Offline starhacker
« Reply #5 on: Mon, 16 July 2018, 13:58:19 »
I'll post some pics. Yes I do use a keycap puller. All the other keys are in in good shape. From what I can tell, only the "1" and "5" caps split.
Offline starhacker
« Reply #6 on: Mon, 16 July 2018, 14:21:12 »
Lotto ticket here I come. Thanks for the email. Hopefully I can get some replacements. Even though the glue is holding well, the stems now fit a bit loose.
