Author Topic: Diagnosis of poker 2 failure  (Read 1912 times)
Offline heattac
« on: Wed, 18 July 2018, 04:49:16 »
Hello guys!
I'm new here so excuse me if this place is not intended for questions like that.
I have (had?) a Pocker II keyboard and today it started to behave weird.
Yesterday I've hibernated my pc, today turned it on and found out that keyboard is not functioning properly:
pressing keys does nothing, then `m` appears, then I've started to push one by one from q, w, r and so on,
then one of the keys `hjkl;'` (not sure which one) triggers programmed keys and I have what I've store before:
key `s` is for `sudo `
+ my username `heattac` (don't remember which key) and then capital letter K all the way down.
I've done factory reset via pressing Fn+R but didn't help.
I've plugged keyboard to another PC and result the same.
behavior is not the same all the times.
Can't figure out what to do.
Please advice,
Thanks
Offline killyou
Re: Diagnosis of poker 2 failure
« Reply #1 on: Wed, 18 July 2018, 11:43:07 »
I would start with asking Vortex.
Offline redbanshee
  • actually Dade Murphy
« Reply #2 on: Wed, 18 July 2018, 11:53:59 »
put the new firmware on it
https://www.ikbckeyboard.com/downloads
Offline heattac
« Reply #3 on: Wed, 18 July 2018, 12:41:45 »
Also when poker is attached I can type only all CAPS with my laptop keyboard.
Offline heattac
« Reply #4 on: Sat, 21 July 2018, 07:08:23 »
I'm not sure but seems that problem was with hight level of humidity outside (it was rainy and window was opened).
Now keyboard works fine after drying it.
