Author Topic: The on/off switch on the back of the Royal Kludge RK61 2.0  (Read 11437 times)
Offline AugustCanaille
« on: Wed, 18 July 2018, 12:26:51 »
Does anyone know what this does? The stupid Chinerican instructions say:
"When the keyboard connects with USB wire, pull the button on the back of the keyboard to ON means wired mode, to OFF means bluetooth mode."
This seems completely backward. For the record, neither work. This thing is a piece of garbage. I was just wondering if anyone knew, exactly, so I could unravel this mystery and make this crapper work.
A manual would help too. I can't even turn on the lights. All of them are ice blue except the spacebar, which stays red forever. I have no idea why.
Offline rich1051414
Re: The on/off switch on the back of the Royal Kludge RK61 2.0
« Reply #1 on: Wed, 18 July 2018, 22:00:35 »
Have you tried unplugging it, changing the switch position, then plugging it back in? This is common for keyboards, and it is possible that is what the chinglish is trying to tell you.
