Author Topic: Issues setting up hhkb bt jp  (Read 2225 times)
Offline ShiverMePenguins
« on: Sun, 22 July 2018, 10:02:54 »
Hi all, I have an hhkb bt jp that I recently got and I can't use the complete layout and was wondering what I need to do in order to fix that? The highlighted sections in the attached either don't work or don't correspond to the correct key? it's almost like it's using an ansi layout however tilda isn't above the esc so idfk what to do?
Offline rxc92
Re: Issues setting up hhkb bt jp
« Reply #1 on: Sun, 22 July 2018, 10:11:48 »
I don't wanna be that guy but.. do you have it set to the Japanese layout on your computer?
« Reply #2 on: Sun, 22 July 2018, 10:15:07 »
2 key secondary is: @ not ". the 2 keys next to L aren't "; (+)" or ":  (*)". key next to /? doesn't actuate at all, the ^ key is = (+). I can use the keyboard but it's a bit of a mess
« Reply #3 on: Sun, 22 July 2018, 10:22:38 »
I did have it setup in Japanese layout but it was set to Japanese layout English keyboard. XD
Offline ag36
« Reply #4 on: Sun, 22 July 2018, 11:40:09 »
You need set it to japanese layout english input mode
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
