Author Topic: ASUS kEEEyboard on Ubergizmo  (Read 4463 times)
Offline ricercar
  • mostly abides
« on: Fri, 23 April 2010, 06:41:22 »
type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385">[/youtube]
Offline Rajagra
« Reply #1 on: Fri, 23 April 2010, 07:13:26 »
Nice. WTF is it though?
Offline erricrice
« Reply #2 on: Fri, 23 April 2010, 07:17:00 »
It's basically a netbook that's just a keyboard.  Pretty cool concept, I think.  Has that small onboard screen but also output(which are meant to be it's main use) so it's very useful for being like a portable workstation type thing.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline kriminal
« Reply #3 on: Fri, 23 April 2010, 08:51:21 »
heh the only use i see for that is being some multimedia keyboard for a htpc or something..
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline ch_123
« Reply #4 on: Fri, 23 April 2010, 09:02:40 »
I like the concept. If Apple was clever, they'd make something like that out of the Mac Mini
Offline wellington1869
« Reply #5 on: Fri, 23 April 2010, 09:03:02 »
its a cell phone with a ginormous keyboard.
I could see writers liking it a lot actually.
Wish the reviewer had turned it on. Is it a regular atom pc?
$599, pre order on amazon: http://www.amazon.com/dp/B003HK5RM6?tag=i4ufututechne-20&camp=213381&creative=390973&linkCode=as4&creativeASIN=B003HK5RM6&adid=0K56DCDK92JRTC9TQKZE&
Product Description
LED-backlit keyboard , 5", 800x480 Multi-touch Panel (Capacitive), Windows XP Home, Intel Atom N270, DDR2 1GB on board memory, 16G SSD + Unlimited ASUS Web Storage (60-day-trial), Broadcom 70010/70012 HD Codec Solution, Ultra-wideband Technology, WLAN 802.11b/g/n @2.4 GHz, 10/100/1000 Mbps, Bluetooth V2.1, Internal Built-in Battery (up to 4 hrs), HDMI out x 1, VGA out x 1, Antenna x 1 (WLAN + Ultra-Wideband), Giga LAN x 1, USB 2.0, x 3, Headphone x 1, Microphone x 1. Also included: Ultra-wideband Receiver (with Adapter), Quick Start Guide/User Manual, HDMI Cable, Mini-USB Cable, Power Adapter, Warranty Card.
Shows the screen: Basically it comes with some apps and connects to the simplified versions of websites, tho if you plug in an external monitor, then it looks like normal XP:
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385">[/youtube]
« Last Edit: Fri, 23 April 2010, 09:18:14 by wellington1869 »
using: ms 7000/Das 3
Offline ch_123
« Reply #6 on: Fri, 23 April 2010, 09:19:40 »
They're still using XP? FFS
Offline itlnstln
« Reply #7 on: Fri, 23 April 2010, 09:24:16 »
Quote from: ch_123;174858
It must be a business-class machine.
Offline Mercen_505
« Reply #8 on: Fri, 23 April 2010, 09:38:16 »
Unfortunately, there are a lot of business as well as industrial software packages that have not been updated to work properly (or certified, to use the lingo) with Vista/7.
Offline itlnstln
« Reply #9 on: Fri, 23 April 2010, 09:41:00 »
Fortunately, everything we use works with 7.  Just don't tell my IT department.  I'm not exactly, uh, testing it or anything.
Offline hyperlinked
« Reply #10 on: Fri, 23 April 2010, 09:41:44 »
I think it'd make for some really cool potential interfaces to have a keyboard with a touch screen and that's certainly one of the selling points of the item, but I'm not all in on it as a portable. It's essentially an awkardly shaped laptop with the low end power of a netbook.
I think it'd be better if they angled this more as an all-in-one device rather than as a portable. If I owned this, I'd like to have a little more juice in it. I wouldn't be carting this thing to the cafe with me, but I might haul it from my office to the living room or to an associate's place to do some work. I wouldn't need it to be a light as possible, just as something that's easy to carry around.
I guess this is all pretty similar to what ch_123 said about this and a Mac Mini. It could be a perfect mobile low end server or groupware connector.
« Last Edit: Fri, 23 April 2010, 09:48:57 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
« Reply #11 on: Fri, 23 April 2010, 10:03:08 »
Quote from: Mercen_505;174871
thats the case at our school, all kinds of financial apps dont have vista/7 versions. Our IT guys are scrambling to make special deals with dell and others to continue supplying XP computers.
« Reply #12 on: Fri, 23 April 2010, 10:05:26 »
Quote from: hyperlinked;174876
It reminds me of the alphasmart a little bit. But with a nicer screen in a way, and functional wifi.
I could see maybe taking it on tech support cases or to a cafe if you're writing fiction.  Would get some stares tho.
« Reply #13 on: Fri, 23 April 2010, 10:06:36 »
Quote from: ripster;174892
Why does it have a keyboard?
its an iphone with a keyboard :)
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #14 on: Fri, 23 April 2010, 10:28:39 »
Networking is a big problem. It's too difficult (read: too time consuming to figure out how) to properly integrate 7 systems on a domain in, for example, a school where the systems need to be totally locked down. Such fluff as homegroups and any other "dumbing down" of the networking features makes it tricky for someone who's been supporting XP/2k machines for a large part of their career.
That said, if that dumbing down were possible to easily remove from the picture...I'd appreciate knowing myself because I might just find it tolerable enough to install again.
kishy.ca
Offline itlnstln
« Reply #15 on: Fri, 23 April 2010, 10:36:38 »
Windows 7 Pro * + domain name = problem solved.  It took me less than 2 minutes to get on my work domain.  Really, once you get to the network adapter properties (which is about 1 extra click), it's the same as it has been for years.  The stupid Network and Sharing Center is a little dumb, but pretty easy to ignore.
*Windows 7 Home Premium does not support domains, though.  It's, basically the only difference between the two.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #16 on: Fri, 23 April 2010, 10:59:28 »
Oh, so that just...takes care of it?
In that case, looks like I need a domain at home.
kishy.ca
Offline itlnstln
« Reply #17 on: Fri, 23 April 2010, 11:04:08 »
Check it:
Offline nraymond
« Reply #18 on: Fri, 23 April 2010, 11:15:56 »
Quote from: erricrice;174815
I'm really indifferent to this ASUS thing.  I'm sure it just has a scissor-switch membrane keyboard in it, and I'm having a hard time picturing how having that tiny touch-screen monitor built into it is truly useful.
If a Commodore VIC-20 and the Logitech G19 keyboard had sex, the ASUS ASUS EeeKeyboard would be their child, and I'm just not sure the world needed that to happen.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #19 on: Fri, 23 April 2010, 20:23:10 »
I think it's high time that Cybernet had some competition.
Offline phoenix
« Reply #20 on: Fri, 23 April 2010, 23:22:22 »
I actually thought about doing this to a terminal board, replacing the numpad area with an iphone dock, where the iphone can lie flat and be used as a touch pad, or the top f-key rows with an iPad dock, which i think will make the keyboard look sort of like a typewriter. I've been searching for dead apple wireless keyboards on ebay for this.
Quote from: wellington1869;174847
Offline ch_123
« Reply #21 on: Sat, 24 April 2010, 04:21:53 »
I was thinking of a more drastic version of that - getting something like a beagleboard and sticking it inside the keyboard.
Offline hyperlinked
« Reply #22 on: Sat, 24 April 2010, 04:38:06 »
Quote from: phoenix;175319
Someone sorta already did this. It's not an actual dock and it's meant to hold any smartphone.
USB 2.0 Keyboard + Smartphone Stand by Matias
Offline InSanCen
« Reply #23 on: Sat, 24 April 2010, 18:08:26 »
google "God mode win 7" and You can bypass almost all the fluff that Win7 has when you just want to change a setting damnit!
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
