Author Topic: gmk violet tendencies  (Read 4029 times)
Offline juntheboon
« on: Mon, 23 July 2018, 15:04:52 »
what's the best way to acquire group buy sets that are listed as sold out? is there just aftermarket or do vendors have some to sell?
got any?
Offline chuckdee
Re: gmk violet tendencies
« Reply #1 on: Mon, 23 July 2018, 15:07:03 »
Sometimes after manufacture, the GB runners will have extras, though there will most likely be a premium added.  You can also check /r/mechmarket on Reddit after the set is delivered as some will part with them for varying reasons.
« Reply #2 on: Mon, 23 July 2018, 22:30:38 »
this
