Author Topic: Generic KLE file for GMK sets  (Read 6536 times)
Offline azeria
« on: Mon, 30 July 2018, 13:18:38 »
Since I couldn't find one of these anyway *(maybe i'm an idiot)*, I decided to make a generic keyboard layout editor file for GMK base sets so keycap designers can just work from that and save some time.
Code: [Select]
["Esc",{x:1},"F1","F2","F3","F4",{x:0.5},"F5","F6","F7","F8",{x:0.5},"F9","F10","F11","F12",{x:0.25},"PrtSc","Scroll Lock","Pause\nBreak"],
[{y:0.5},"~\n`","!\n1","@\n2","#\n3","$\n4","%\n5","^\n6","&\n7","*\n8","(\n9",")\n0","_\n-","+\n=",{w:2},"Backspace",{x:0.25},"Insert","Home","PgUp",{x:0.25},"Num Lock","/","*","-"],
[{w:1.5},"Tab","Q","W","E","R","T","Y","U","I","O","P","{\n[","}\n]",{w:1.5},"|\n\\",{x:0.25},"Delete","End","PgDn",{x:0.25},"7\nHome","8\n↑","9\nPgUp",{h:2},"+"],
[{w:1.75},"Caps Lock","A","S","D","F","G","H","J","K","L",":\n;","\"\n'",{w:2.25},"Enter",{x:3.5},"4\n←","5","6\n→"],
[{w:2.25},"Shift","Z","X","C","V","B","N","M","<\n,",">\n.","?\n/",{w:2.75},"Shift",{x:1.25},"↑",{x:1.25},"1\nEnd","2\n↓","3\nPgDn",{h:2},"Enter"],
[{w:1.25},"Ctrl",{w:1.25},"OS",{w:1.25},"Alt",{a:7,w:6.25},"",{a:4,w:1.25},"Alt Gr",{w:1.25},"OS",{w:1.25},"Menu",{w:1.25},"Ctrl",{x:0.25},"←","↓","→",{x:0.25,w:2},"0\nIns",".\nDel"],
[{y:0.5},"|\n\\","~\n`",{c:"#000000",t:"#cccccc"},"Esc",{x:5.75,c:"#cccccc",t:"#000000"},"Delete","End","Pg Dn",{x:1},"¬\n`","\"\n2","£\n3"],
[{w:1.5},"Backspace",{w:1.5},"|\n\\",{x:6.75},"Pg Up","-",{x:2.75,w:1.25,h:2,w2:1.5,h2:1,x2:-0.25},"Enter"],
[{w:1.25,w2:1.75,l:true},"Caps Lock",{x:0.5,w:1.75},"Ctrl",{n:true},"F",{n:true},"J",{c:"#000000",t:"#cccccc",w:2.25},"Enter",{x:2,c:"#cccccc",t:"#000000"},"Pg Dn","+",{x:0.75},"@\n'","~\n#"],
[{w:2.25},"Shift",{w:1.75},"Shift","Fn",{w:1.25},"Caps Lock","Alt","Ctrl",{x:2.5},"End",{x:1.75,w:1.25},"Shift","|\n\\"],
[{w:1.5},"Control","OS",{w:1.5},"Alt",{w:1.5},"Alt Gr","OS",{w:1.5},"Control",{x:1.75},"00","0\nIns"],
[{a:7,w:7},""]
Re: Generic KLE file for GMK sets
« Reply #1 on: Mon, 30 July 2018, 21:49:40 »
i prefer this layout setup because it has a little more compat
this is a colorway i have long abandoned but yeah if you need a basic KLE this one works as well
covers all the important stuff
Offline KHAANNN
« Reply #2 on: Wed, 01 August 2018, 03:53:33 »
Some JS/CSS3 magic to make the keycaps look like actual GMK keycaps would be awesome, I assume it's doable, but likely very exhaustive
Offline hotmaillogin
    • hotmail login
« Reply #3 on: Fri, 03 August 2018, 02:23:10 »
This really interesting post. Thanks for sharing!
Offline KHAANNN
« Reply #4 on: Fri, 03 August 2018, 02:25:17 »
Sir I entered my hotmal login/password but it didn't work?
