Author Topic: Filco keycaps and oily fingers (not from eating :P )  (Read 4248 times)
Offline muchadoaboutnothing
« on: Fri, 23 April 2010, 15:22:44 »
Hello geekhack!
Still lurking a lot here... :peace:
So, after my first post/thread asking for a KB recommendation given finger pain from my membrane, I bought an ABS M1 when Newegg had it on sale for $20.
I'm happy to report that I'm happy with the M1- although going from ergonomic split -> straight keyboard is throwing me for a loop on accuracy at 80+ WPM, I'm happy to report that I adjusted to the tactile feedback quickly and I'm not having any pain right now when typing for long periods, when I could get it in 30 minutes of fast typing if it was continuous (e.x. TypeRacer :pout: )
Anyhow.... I have a tendency to ramble...
I've been looking at the Filcos. As a possible way to reduce finger strain, and alienate anyone who may want to use my computer :pound: I was thinking about trying DVORAK (which would reduce travel...I'm not in pain now, but having it as a college student probably means it's going to be a problem later in life). To make it easier to switch back and forth (to let someone else use the PC, or if I decide to give up on DVORAK, etc.) I was thinking about getting an Otaku. This might also be a good idea for another reason...
I have naturally oily hands. Moreso than many people. Not as much as my family members (like my grandfather...)
Keyboard wear tends to show quickly. People I know have bought identical laptops at the same time and my keys show more wear than theirs.
Now, I know what you're probably  thinking- blank keys? Wear? Well, on some of my peripherals, I get shiny/dull/unpainted spots because the finish wears off. That's kind of a turn off on a product that's over $100, even if you don't look at the keyboard while typing (I don't - I use the home row nubs. Or is there a technical term for those bumps?)
So do Filco keys hold up over time?
« Last Edit: Fri, 23 April 2010, 15:27:28 by muchadoaboutnothing »
Offline Rajagra
« Reply #1 on: Fri, 23 April 2010, 15:51:25 »
I have no experience with Filcos, but I suggest:
  • Before commiting to Dvorak, take a look at Colemak.
  • If you want to be kind to Qwerty users, just use a Qwerty keyboard.
  • If you want to learn to touch type Dvorak/Colemak, use a Qwerty keyboard!
  • I wonder if wiping the keycaps with ArmorAll once a week might reduce your key wear (may be caused by acid in sweat?)
« Reply #2 on: Fri, 23 April 2010, 16:06:19 »
Quote from: ripster;175134
You mean blank Filco keys?
Yes
Get the white ones if shiny bugs you.
It doesn't really solve the problem. Besides, the white keyboards I've seen always have a tendency to look dirty very quickly.
Quote from: Rajagra;175135
Interesting, thank you.
I could do that, but...
I was thinking blank because...
[LIST=A]
  • I can't cheat by looking at the keys- which I might do out of force of habit - and I can't look at the keys, see the QWERTY letter, and get more messed up.
  • I thought it would wear less than printed letters (Q, W, E...so on and so forth)
  • Kinda like the minimalistic look (not enough of a minimalist to get rid of my numpad, though!
It's something with the sweat...I have other family members who get white spots on their mice (where their fingers are) in a month or so.
Might be worth trying.
Offline Rajagra
« Reply #3 on: Fri, 23 April 2010, 16:56:55 »
Quote from: webwit;175165
Wet your finger, touch the sandblasted key, and see what happens.
Don't. It's a trap!
Offline Mental Hobbit
« Reply #4 on: Fri, 23 April 2010, 17:11:58 »
Same effect as water on a stone I guess.
Typing on blues.
« Reply #5 on: Fri, 23 April 2010, 19:49:58 »
I don't think stainless keycaps will ever be in my budget... :P
Custom plastic ones are, what, 50 cents a key (assuming you do a run of ~50)?
« Reply #6 on: Sat, 24 April 2010, 17:28:11 »
Quote from: ripster;175284
More like $800 for 104 keys for dye sub - assuming you are buying for only one keyboard.  Setup costs are not trivial.
Makes $330 for 86 Aluminum keys look good.
$800 for 104 keys dye subbed for a single set, right?
So if you make 50 sets (you found a group of buyers), the setup costs become dispersed.
« Reply #7 on: Sat, 24 April 2010, 17:54:07 »
Quote from: ripster;175582
Yep, that's what Sixty did to make his one custom GeekHack key and get them to around $5 in cost each.
Shiny isn't so bad.
They DO look nice...
I can see the where the economics become different.
When you have a single key for a single site you can probably depend on a lot of people to buy it.
But a larger set is more expensive, people could back out...
I wonder how many people would be interested in buying a dye-sub set...
What about double shot? That's crazy expensive, right?
Offline EverythingIBM
« Reply #8 on: Sat, 24 April 2010, 20:56:28 »
Model M keys are very grainy and can usually sustain against greasy fingers. Get one cheap if you can and try it out for a bit.
The other layouts aren't that all great, I can type over 100 WPM on qwerty; typing speeds depend on how good your fingers are (biologically), and trained to type. I play the piano a lot: so that may enhance typing.
