Author Topic: [ENDED] NIB Cherry G80-11900 (MX Silent Blacks), $47.84 shipped  (Read 7145 times)
Offline ander
  • I type, therefore I am
« on: Sun, 05 August 2018, 01:49:17 »
Cherry G80-11900 Mechanical 104-Key PS/2 Touchpad Compact Keyboard G80-11900LTMU
Customer return. BIN $29.95 + $17.89 US shipping.
I used DT's Cherry Article Numbers page to determine the switch type.
« Last Edit: Fri, 10 August 2018, 03:58:57 by ander »
Offline Giorgio
Re: NIB Cherry G80-11900 (MX Silent Blacks), $47.84 shipped
« Reply #1 on: Sun, 05 August 2018, 01:53:23 »
Are you sure that it has silent switches? It seems quite old.
Offline mrhead
  • Thread \ (•◡•) / Stopper
« Reply #2 on: Sun, 05 August 2018, 17:05:03 »
I have one - they're cherry blacks.
Offline Rayndalf
« Reply #3 on: Mon, 06 August 2018, 22:06:02 »
The Windows 8/10 logo on it. That would suggest it was made in the last 5 years?
Given the printing on the box showing the XP/7 logo they must not being selling many of these (perhaps a custom order for medical equipment?), I can't imagine these are still used in rack mount installations, but the dual ps/2 instead of the usb I've seen on XP/7 era 11900s is interesting to say the least
edit: good catch on the article number indicating the switch type! I haven't tried silent blacks before so I bought it, I'll make some post in regards to my findings, it should arrive in a few days.
« Last Edit: Mon, 06 August 2018, 22:13:53 by Rayndalf »
Offline Rayndalf
« Reply #4 on: Thu, 09 August 2018, 16:56:07 »
Like an 1800 I have from the same period, this board has the modern windows logo, but pre retool blacks. They aren't bad, they are fairly stable, but they would clearly improve with use. Despite using dual PS/2, the rollover is acceptable, and an AT and 'RS 232' adapter are included.
Both the box and the board are marked G80-11900LTMUS-2/05, but the stems are identical to a loose black switch I had from a scrap 1800 PCB from TKC. The date code is Z47, which places it at the tail end of 2013
Offline ander
Re: [ENDED] NIB Cherry G80-11900 (MX Silent Blacks), $47.84 shipped
« Reply #5 on: Fri, 10 August 2018, 03:59:40 »
Guys, like I said, I went by the Cherry part no., according to DT's page I linked to.
Offline Rayndalf
« Reply #6 on: Fri, 10 August 2018, 17:09:03 »
Nah, you're good, this was a fair price and I knew it was unlikely. The article number does suggest that it would feature silent blacks, but I should have double checked the date code (it predates silent blacks by a few years). For what its worth, there's only one 11900 on ebay cheaper than this was right now, and its sunburnt with a cut cord (no box or adapters either, go figure :P)
Offline method_
« Reply #7 on: Thu, 16 August 2018, 04:04:12 »
My friend has one as well and they're also cherry black
thock program.
