Author Topic: UNIQEY Q100 is now fully remappable including FN layer  (Read 3076 times)
Offline ag36
« on: Sun, 05 August 2018, 11:59:25 »
https://uniqey.zendesk.com/hc/de/categories/360000396714-UNIQEY-Control-Software-Tool-
The GUI is still a bit primitive but fully functional, hope there will be a TKL version someday.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline fxsound
Re: UNIQEY Q100 is now fully remappable including FN layer
« Reply #1 on: Thu, 09 August 2018, 08:23:31 »
Only the errors that were in the q100  did not correct...
Offline Giorgio
« Reply #2 on: Thu, 09 August 2018, 08:25:38 »
If only there was a fully open source firmware, with a big community and brilliant developers... Imagine what they could have accomplished.
Wait.
Offline ag36
« Reply #3 on: Thu, 09 August 2018, 09:55:35 »
Haha, yeah led 4 is still bugged. Would be great if this was a TKL with QMK/TMK.
Offline Flowshi
« Reply #4 on: Mon, 13 August 2018, 11:37:32 »
Maybe a dumb question: want to map the keyboard with US-Int layout within the board (wanna use it at work but can`t change the OS language settings). So for example an "ö" is alt gr + "p"
Is that possible?
Offline fxsound
« Reply #5 on: Tue, 14 August 2018, 08:31:00 »
« Last Edit: Tue, 14 August 2018, 08:33:28 by fxsound »
Offline Flowshi
« Reply #6 on: Tue, 21 August 2018, 11:24:04 »
Contacted the GMK Support with request for:
-firmwareupdate Q100 for LED4
-request for more layers in the softwaretool
Their hardware is pretty impressiv, but it lacks a good software and updates (firmware).
Offline Giorgio
« Reply #7 on: Tue, 21 August 2018, 14:16:38 »
Just ask for tmk qmk support. I did.
Offline fxsound
« Reply #8 on: Thu, 23 August 2018, 02:42:29 »
About errors in q100 they know for a year already. They are so complex that it is not possible to fix it 8))))  -= sarcasm=-
Offline Giorgio
« Reply #9 on: Thu, 23 August 2018, 04:46:50 »
LOL
